09-10-2014 12:58 PM
I haven't had any problems with my 1.5 year old 60D until last week when suddenly I couldn't switch to my spot meter. The back screen says it's on spot metering, but the camera meters in evaluative mode. I tried removing and reinserting the battery, but no change. Any ideas? Thanks.
09-10-2014 01:09 PM
Solved my own problem! I switched the manual selection spot to the center and the spot metering kicked in. I'm a bit concerned that the glitch may be symptomatic of some issue that will be worse down the line. Has anyone else had this problem before?
09-10-2014 01:09 PM
