Can not Factory rest
Senathipathi_j
Hi
I am Using cannon Eos 1300d (Rebel t6). Now it showing “This function is not selectable in the current shooting mode” in all mode. If I try to factory rest “Clear all setting” not showing. How to reset my camera? Using computer?
12 REPLIES 12
Read my question again
1) "..in all mode" means including Manual mode
2) You said (Please reference your manual to learn the different modes and how to reset your camera) but,in manual mode can not open menu to rest the camera (As per manual)
3) "The Forums aren't intended for immediate assistance. If your question is urgent" is very vulgar reply. I did not ask immediately assistance. At the same time reply should not confuse other contributors who know the solution. Your reply showing me that you too confused by ebiggs1's reply which contains the answer to the question of "what are the benefits of using dslr?". I am new to this forum but ebiggs1 is "forum elite". it does not matter. wrong is wrong.
Screenshot 2022-04-24 at 1.57.01 AM.pngScreenshot 2022-04-24 at 1.57.01 AM.png
Waddizzle
I am beginning to suspect that perhaps your Shooting Mode Dial is faulty.
When you press the Quick Menu, [Q], button, you should see the shooting mode in the top left corner.  When you change the Shooting Mode dial from P, Tv, Av, or M, does the letter in the top left corner of the Quick Menu screen change with it?
ebiggs1
Senathipathi_j said, "This functioathipatn is not selectable in the current shooting mode”
This indicated to me that you were shooting in a full auto mode. That is why I offered, "I would advise you to never use any of the fully automatic modes." For your current situation and future situations also for the reasons explained. Everybody here is  here to help. Also every bit of advice is given freely. You therefore need to decide whether you want to make use of it or not.
If you had heeded that advice you would have seen the reset ability become active.
EOS 1DX and many lenses.
