09-14-2024 02:49 PM
I own a Canon 80D DSLR camera which I love and still use as my back up camera to my other Canon R6 M2 Mirrorless. I also own 2 batteries each for each camera, however in the winter months I go out shooting in zero (-18 Celsius) and 5 degrees Fahrenheit (-15 Celsius) I know that the cold drains a battery faster than hot.
I charge them all in the same charger.
R6 mk2 = LP-E6NH
80D = LP-E6
My question, has anyone's camera had any adverse effect or, is there anything I should be concerned with if I do happen to use the 80D battery in the R6 mk2 or visa versa in the field?
09-14-2024 06:00 PM
You can use LP-E6NH batteries in both bodys. You can use the LP-E6 in the R6mkII too, it just won't last as long. I think its discontinued now or will be soon.
I've started ordering LP-E6P's. This is the newest battery for the R5 mkII. It has a constant discharge rate of 6A.
Co-pilot and chat GPT say the E6P isn't backwards compatible with the R6mkII but I bet it is. It works in my R5 C.
09-14-2024 06:00 PM
