07-16-2024 05:44 PM - last edited on 07-16-2024 06:19 PM by Tiffany
Hey I need urgent help my eos 1300d won't turn on with my third-party batteries which are only 6 months old it worked well till yesterday but today when I tried to turn on my camera it won't but it gets on with my old Canon lp-e10 battery which are damaged. Please help me
07-16-2024 05:50 PM - edited 07-16-2024 05:52 PM
Wait. So it works with the old batteries? I suggest you get some new ones. Canon if possible.
Leave the batteries out a few days while charging them and then put them back in the camera. (Does the red SD access card flash when you put the batteries in?)
Then try turning it on again. If that does not work, you probably need it serviced.
07-16-2024 07:23 PM
As I read it OP states it works with the old Canon batteries but not with newer third party batteries.
I don't think anything is wrong with his camera; its a battery issue.
I do agree about getting new Canon batteries unless he can find recognized reliable third battery products.
07-16-2024 06:09 PM
With third party anything, you are using them at your own risk. If the batteries have died prematurely, and you have the documentation to do so, I would suggest approaching the vendor of said batteries. I would suggest getting Canon brand or at least a different 3rd party brand to replace them.
07-16-2024 07:17 PM
What brand are the failed batteries? The battery market is rife with junk. If you want an aftermarket battery that is a good bet, see if Watson or Wasabi make one for your camera.
