12-11-2020 11:26 AM
Hi there. I took some photos that I'd like to upload to my computer-- but for some reason I can't? For context I have a Canon EOS M50.
I tried plugging in my sd card and it had every photo except for the ones I took that day. So I gave it a week and tried again-- and again it didn't work. I tried using the bluetooth function and app, and it ony had photos from like 3 months ago and before. I need these photos on my computer as soon as possible. What am I doing wrong?
12-11-2020 11:50 AM
Is it a full size card, or a micro card with adapter?
12-11-2020 12:52 PM
12-11-2020 02:27 PM
Can you put the card in the camera and see the photos that you recently took?
BTW, buy a new SD card. Buy a 32GB Sandisk UHS-I card. No need to buy a high capacity card.
What type of computer are you using, or transferring the files to? Just before you initiate a transfer, have tried to manually select which files you want to download?
12-11-2020 05:09 PM
As first doublecheck if the pictures are not already on the computer folder but just coming out at the end or at beginning of the list or at the end, eventually after any subfolder you may have in that folder.
It happened to me with the EOS M6 that since few pics were not JPG but CR2 I could not see them in the order I expected them.
Also since I did not have a proper extension I could not see them as picture using the large icon view. If that is the case you need either to use Canon DPP to open them or to install an additional software in order to be able to visualize these files properly.
12-12-2020 12:24 PM
"What am I doing wrong?"
Try a separate SD card reader. Use your comouter's file handling app to see if they are truly there.
