Camera setting question
UPinFocus
I've been asked to take pictures for a "red carpet event". The event will have an area with a backdrop set up for pictures. I just got my camera yesterday....rebel T6. What would a good setting/mode to use? Also I am brand new to the DSLR cameras. Thanks!
14 REPLIES 14
kvbarkley
VIP
VIP
Do you have an external flash? Do *not* use the built in flash, you will get mug shots, not portraits.
There are too many variables to answer. For you, just keep it on Green Square or Portrait.
UPinFocus
Nope just a camera and the flash that came with it. I have the 55mm lens and the I believe its 300mm lense. Both came with the package.
BurnUnit
Whiz
Whiz
Oooooof! Sounds like you've really got your work cut out for you there.
Do you have access to the event area so you can experiment a bit ahead of time? Do you know the specific lighting conditions you'll be shooting under? If you don't have a suitable flash hopefully the shooting area will be well lit. You may need to shoot at higher than normal ISO which takes an extra bit of skill as well. It may be difficult to get sharp, clear images if you're shooting hand-held.
If you're expected to get semi-professional or better quality images, you might want to pass the job along to someone else. If you just need some casual looking snapshot images, stick to the auto modes as mentioned above and be liberal with the amount of shots you take. Make sure you've got a spare battery and plenty of room on your memory card(s).
Spend as much as time as you can doing some random shooting just to get used to the layout and controls on your new camera. You don't want to have to learn all this stuff the night of a big Red Carpet event.
ebiggs1
"...you will get mug shots, not portraits."
I would avoid any flash if at all possible. However, you have very slow lenses and external light may be required. Without actually seeing the venue nobody here can tell you what setting or gear to use. But a basic bag would include a much faster preferably constant aperture lens.  The Canon EF-S 17-55mm f/2.8 IS USM Lens is an great example. Off brand choice could be the Sigma 18-35mm f/1.8 DC HSM Art Lens.
The suggestion of checking the venue out before hand is good.  Do it if possible and take test shots.
" I have the 55mm lens and the I believe its 300mm lense. Both came with the package."
This gave me cause to suspect.  Did you happen to buy one of the 'kits' from an Amazon type store?  You got a bunch of stuff with it like filters, bag, add on lenses and other worthless items?  If, yes, return it today. You got mostly junk.  Buy the Rebel from a good know retailer like Best Buy, B&H, Adorama, Roberts and better perhaps a local camera store.
You can buy a kit specifically designed for your requirements.  These stores will have people you can ask questions about what you want to do.
UPinFocus
I got it from best buy. 2 lenses and a bag and battery.
OK that is good.  Next step is to go to the venue and try a shot or two.  Try different settings.  P mode is a good starting place.
Good photographers do not like surprises!
Will the event be televised? If so, you may be able to sponge off the TV lights to avoid, for example, having to fire a flash in a speaker's face. I've sometimes had the TV lights turned on, even when the event wasn't being televised, just to have better ambient light available. There are advantages to being the official event photographer. Don't be afraid to exploit them if the opportunity arises.
Bob
Go back to Best Buy and purchase an SD memory card.  I recommend Sandisk Extreme 32 GB UHS-1 cards.  Ony buy the full size cards.  The micro-SD cards with the plastic adapter to make them fit in a full size slot are unreliable, and are not recommended for use by Canon.
As far as Camera exposure settings go.  The Green [A] mode, Automatic, is the easiest to use.  The camera will behave like a classic “point and shoot” compact camera.  The mode for learning the camera is P mode, and shoot as RAW + JPEG.  Use [CA] mode when you want automatic exposure behavior, but with the flash disabled.
Other than that, the best advice is to get out there and practice taking photos.  Practice getting photos out of the camera.  Practice using the Canon Digital Professional Software to enhance your photos, especially the RAW files.
Holiday
EOS C400 - Version 1.0.4.1
EOS C80 - Version 1.0.4.1
XF605 - Version 1.0.7.1
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
