09-15-2021 11:24 AM
I have had problems with 70D and 90D. A black streak goes across the image making the camera unusable. What am I doing wrong?
09-15-2021 12:10 PM
Post a picture, but it appears you have a broken shutter.
09-15-2021 12:14 PM
09-15-2021 12:41 PM - edited 09-15-2021 12:41 PM
That does look like a failing shutter. Are you saying that both your 70D and 90D have the same problem?
09-15-2021 12:44 PM
I have had 2 70D cameras and one 90D camera with the same problem. Just trying to see if I'm doing something wrong. the problem has happened while I was using a Canon 70-200m lens.
09-15-2021 12:50 PM
It seems highly unlikely that all 3 of your cameras have a failing shutter.
I would suspect a lens problem in your case. You may have an aperture blade failing on the lens. Does the problem only happen with that one lens?
09-15-2021 12:55 PM
The lens has worked fine on other cameras. Can the lens cause a problem with the camera?
09-15-2021 01:27 PM
@Barry65 wrote:The lens has worked fine on other cameras. Can the lens cause a problem with the camera?
Worked fine on other cameras at the same time as the three cameras you mentioned have a problem, or worked fine at other times?
09-15-2021 01:33 PM
I have used the Canon 70-200 lens for 5 and a half years on three different Canon cameras: 2 70 D's and one 90D. My problems with all three cameras happened when I was using that lens. In other words, after I couldn't use one Canon camera anymore, I used the lens on the next Canon I bought and it worked until the same problem happened. And then again with the 90D which failed last night.
09-15-2021 01:36 PM
I have a remaining 70D and the 70-200 lens is working on that camera. Could the lens cause damage to the camera?
