CF not reading
Ellabean5154
I have a Mark 2. I took out my CF card (it has worked from the day I got the camera) when I put it back in the camera won't read it and won't format the card. Any advice or help?
2 REPLIES 2
jrhoffman75
If it worked when you removed it and doesn't now one thing to check is remove the card and look in the card slot. Do you see any bent pins?
Moderator
Moderator
Thanks for joining the conversation, Ellabean5154!
So that the Community can help you better, we need to know exactly which Canon camera model you're using as we've made several cameras with the "Mark II" designation. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
