06-30-2020 12:24 PM
VIDEO SHOOTING USING CANON EOS90D WITH PERCEPTION WIRELESS 45 SPORTS SET. WHEN PLAYING BACK VOICE AND MUSIC WILL NOT BY HEARD SIMULTANEOUSLY. WHEN I SPEAK THE MUSIC STOPS AND VICE VERSA.
06-30-2020 01:39 PM
I suggest you take it up with the PERCEPTION WIRELESS 45 SPORTS SET people. The 90d can only record what it is given. It can't tell the difference between music and voice. Sounds like a ducking issue.
06-30-2020 02:32 PM
Thanks for the reply. "Sounds like a ducking issue". What odes that mean?
06-30-2020 02:39 PM - edited 06-30-2020 02:40 PM
https://en.wikipedia.org/wiki/Ducking
It could be that the wind filter is causing this, you might try turning that off.
06-30-2020 02:43 PM
It could also be the agc. When the music is playing the gain is automatically set at a certain level. When the louder voice comes in, the agc turns down the gain to prevent distotion. This turns down the music, too.
06-30-2020 02:58 PM
Hello,
Maybe I'm articulating this inqiury well. My producing a fitness video. In the process of recording I'm speaking while music from external source is playing in the background. There's a connection from the canon eos90D to the voice amp. When playing back When I'm speaking it's ad if the music is turned off. When I pause speaking the music kicks . Someone from Canon yersterday suggested it was a channel issue with both Canon eos90d and the PERCEPTION WIRELESS 45 SPORTS SET being on the same channel.
I've tried recording with the wireless mic on channels 3-8 since I told the Canon is right and left or 1 and 2.
06-30-2020 03:07 PM
Typo "Maybe I'm articulating this inqiury well." Maybe I'm NOT..."
06-30-2020 03:15 PM - edited 06-30-2020 03:15 PM
I still don't know your setup, how do the music and voice get combined? But I can guess that your voice is so loud, the agc lowers the music. Have you tried whispering as a test to see if it still happens?
06-30-2020 03:28 PM
Thanks for the help. I should've taken some images of the setup. I won't be able to get to the equipment until tomorrow. one last thing if don't mind...how do I disable the AGC?
06-30-2020 03:36 PM
@yvoncey wrote:Hello,
Are you recording audio from a headphone output. Yikes. Are you setting the audio level to manual?
