03-27-2013 12:22 PM
NO FOCUSING, NO SCREENS, NO PLAYBACK. WHAT SHOULD i DO?
03-27-2013 02:53 PM
03-27-2013 05:16 PM
If you have access to a voltmeter check to see if it's actually fully charged. A defective cell can do things like this.
03-27-2013 06:11 PM
I'VE TRIED IT WITH 2 BATTERIES. THE LENSES (i TRIED 24-70 F2.8, 85MM 1.2 AND A 70-200 F2.8) WITH THE SAME RESULT. rEAR SCREEN BRIGHTENS WHEN SWITCH IS FLIPPED. NO IMAGE ON SCREEN, IN VIEWFINDER OR IN THE TOP SCREEN
03-27-2013 06:57 PM
03-28-2013 09:32 AM
You didn't say if the batteries are Canon or off-brand. Off brand batteries can cause all sorts of problems. You really do need to try a known good Canon battery. The lens being attached makes no difference.
Did the camera get dropped or wet?
03-28-2013 02:27 PM
Both batteries are canon's own. The camera was in a rain event this past July in India but survived the trip and took many extraordinary photographs. This just occurred while I was inside, shooting through a closed window.
03-29-2013 08:47 AM
OK, sorry but it looks like you are in for a repair bill. If a camera gets wet, it isn't really all that bad. It is using it while wet that usually does the damage. Not saying that is your issue since it was so long ago. Also, if a camera is damaged by getting wet, it may not be price wise to fix it.
Provided you are certain your batteries are good and you have done a hard reset?
03-29-2013 06:20 PM
@CANONUSER46 wrote:I'VE TRIED IT WITH 2 BATTERIES. THE LENSES (i TRIED 24-70 F2.8, 85MM 1.2 AND A 70-200 F2.8) WITH THE SAME RESULT. rEAR SCREEN BRIGHTENS WHEN SWITCH IS FLIPPED. NO IMAGE ON SCREEN, IN VIEWFINDER OR IN THE TOP SCREEN
Doesn't sound good.
By "no image in viewfinder" you mean it's completely black (so mirror is locked up)?
Is there any sign of moisture condensation inside the top LCD panel or anywhere else?
10-15-2016 08:01 PM
I had the exact same thing happen to me today. 5D MKII. Same exact symptoms as your's. I have also tried everything you did to no avail. Did you ever resolve your problem and if so what did you do? Thanks!
