Blinkies: How can I capture an image with the blinkie background and the resultant after glow?
R5RAY714
14 REPLIES 14
Maybe the OP is wanting to put together a tutorial or such and wants to show what the display looks like when the Highlight Warning is enabled. I think I'd try to take a photo of the LCD when the proper effect is displayed. If you needed to show it actually blinking you'd want to take multiple images and combine them in an animated GIF.
kvbarkley
You should be able to hook up the HDMI and a capture card to get exactly what is on the LCD. As to why, I am mystified, too.
ebiggs1
In Photoshop you can do this whether this is what the OP wants, I don't know but it is possible. If all you want to do is show an overexposed area you can make that in PS also.
A GIF, whether animated or not, is just an image file type.  It can be from any type of image. If it moves it will be several or a series of images. Simply load your images and open each one in a layer in Photoshop. Open the Timeline panel and select Create Frame Animation. Select Make Frames from the layers in the Timeline panel. Set the GIF to loop.
What you do with it after this is up to you.
EOS 1DX and many lenses.
Lightroom as well can show areas of overexposed parts of the photo.
-jaewoo
Rebel XT, 7D, 5Dm3, 5DmIV (current), EOS R, EOS R5 (current), R50V (current)
