Search instead for
Black "lines" at top and bottom of viewfinder
nexgraphics
hi...I have a Canon EOS T8i and im trying to figure out what the black "lines" at the top and bottom of the viewport are when I press down the shoot button.  Can I get rid of them?   thanks!
Your camera is an APS-C 'crop' sensor camera.  However, this is not about the overall dimensions of the sensor, it is about the format that you want to shoot in.  The traditional proportions for film and a sensor are 3:2, which uses the full area of the sensor.  However, many people post their images on screens that display in 19x10, or for image composition purposes even on 1:1.  When you went to the screen to change the lines you would have seen a list of different proportions listed, as per the image on Newton's last post.  In that case the camera reduces what the sensor records to the various proportions shown.  The lines on the screen are to help you compose your image to the new proportions.  On mirrorless cameras, which don't use an optical viewfinder, the image is displayed in the chosen proportion to the electronic viewfinder.
I would recommend, if you have not done so, downloading a copy of your manual from Canon, and use that to check these things - you will find it a wealth of information.
cheers, TREVOR
Professional photographer, engineer and educator since 1980
"All the beauty of life is made up of light and shadow", Leo Tolstoy;
"A good swordsman is more important than a good sword" Amit Kalantri
Technique will always Outlast Tech - Me
6 REPLIES 6
If by "lines" you mean bars, please check your aspect ratio. I'm pretty sure it should be 3:2 by default, which is full frame.
Newton
Thank you - that worked!   But question, as I was told that this camera is NOT a full frame camera....so is it then?
cheers, TREVOR
Thank you very much!
You're welcome.  Definitely download your manual though - you will be amazed at the stuff you can learn! 🙂
cheers, TREVOR
Sorry, I should have been more clear and said "entire frame" or "THE full frame" to eliminate any confusion. I won't take it any further as Trevor has pretty much explained it.
Newton
07/28/2022: New firmware version 1.2.1 is available for EOS-R3
07/21/2022: New firmware version 1.6.0 is available for EOS-R5
07/21/2022: New firmware version 1.6.0 is available for EOS-R6
07/21/2022: New firmware version 1.1.0 is available for EOS-R7
07/21/2022: New firmware version 1.1.0 is available for EOS-R10
07/01/2022: New firmware version 1.3.0 is available for PowerShot PICK
06/30/2022: Service Notice: EOS 70D: Error 70 or Error 80
06/07/2022: New firmware version 1.0.3 is available for EOS M50 Mark II
04/26/2022: New firmware version 1.0.1.1 is available for EOS R5 C
02/07/2022: New firmware version 1.6.1 is available for EOS-1DX Mark III
01/05/2022: Welcome to CES 2022!
12/7/2021: New firmware version 1.3.0 is available for Mount Adapter EF-EOS R 0.71x
