09-30-2013 08:33 AM
What is causing these lines on 75% of my pics??? doesn'thappen in all?? Switched cards?? still get lines?/ Thanks
10-08-2013 09:37 AM
09-30-2013 08:45 AM
Hi Rumbley!
So that the Community can help you better, we will need to know exactly what equipment you're using. Any other details you'd like to give will also help the Community better understand your issue.
Thanks and have a great day!
09-30-2013 09:27 AM
I'm using a Canon EOS Rebel T3 on full auto with a PNY premium SD. I switched cards and STILL get lines in
some not ALL of my pics?? I get the verticle lines in my screen BEFORE taking picture sometimes?? Could the camera be faulty?
09-30-2013 11:26 AM
There are no user settings that would cause that. The only thing outside of the camera that I could think of is the card, but you said you switched that. I'd send it in to Canon.
09-30-2013 12:06 PM
Thanks. That's whayt i was afraid of. Just seems odd some photos don'tget affected??
09-30-2013 12:18 PM
Look like the image is corrupted. It is most likely the card problem or the card reader. Do you use card reader? I doubt it is a camera problem. Try to format the card in camera, then take a few photos, then transfer it to your computer using different card reader or using different cable if you can.
09-30-2013 12:45 PM
Will do. Thanks I DID trya different card and got a bad image But I hadnot formatted it.. I'll try that. Thanks Again
10-08-2013 09:37 AM
Sent body back to Canon
