01-10-2021 04:22 AM
01-10-2021 08:43 AM - edited 01-10-2021 10:26 AM
How to "fix" if its possible.
Charge the battery fully.
Allow the battery to fully discharge (use normally) until depleted
Charge the battery fully again
Allow to fully diischarge (use normally) until depleted
Charge fully again. At that point, if the battery was not permanently damaged and is salvageble, it should be at or near what its full capacity once was.
If not, the battery has failed and will need to be replaced.
This process has many names. "Recalibration", "exercising", "cycling" etc. Moral, don't leave batteries inside the camera if you don't plan to use it after a week or more.
01-10-2021 06:10 AM - edited 01-10-2021 06:12 AM
From batteryuniversity.com:
"Lithium-ion should not be discharged below 2.50V/cell. The protection circuit turns off and most chargers will not charge the battery in that state. A “boost” program applying a gentle charge current to wake up the protection circuit often restores the battery to full capacity.
There are reasons why Li-ion is put to sleep when discharging below 2.50V/cell. Copper dendrites grow if the cell is allowed to dwell in a low-voltage state for longer than a week. This results in elevated self-discharge, which could compromise safety."
01-10-2021 06:52 AM
01-10-2021 09:00 AM - edited 01-10-2021 09:09 AM
I have done the same with LP-E6 and followed this tutorial https://www.usa.canon.com/internet/portal/us/home/support/product-advisories/detail/adv-batt-charger...
A third-party charger may also be an idea, just to boost the battery above 3 V.
01-10-2021 09:53 AM
Thanks for the suggestion. Tried and it seems the battery is working better now. Hopefully it'll retain the charge and work without a hitch. I will make sure I remove the battery and store it safely (and separately) since I dont use my camera every week.Thanks !
01-10-2021 11:50 AM
" A few days back, I accidentally left the camera in ON position (LCD etc were all off) for 3 days."
Double check your settings. There is an Auto OFF timer in the menu.
