02-17-2020 07:44 AM
I am drawing a blank, what kind and where can i purchase a USB cord for my EOS 90d so I can transfer images right from camera to MacBook and also to check shutter count. Also does any one know whta kind of USB cable a 1dx Mark ll uses. I am looking at buying a used model from friend and they do not have one, also want to check shutter count. Thanks
02-17-2020 09:18 AM - edited 02-17-2020 09:52 AM
1D X series report shutter count in 1000 blocks right in the camera.
02-17-2020 09:31 AM
Any USB type-mini-B cable should work. Just make sure it is not a charging cable.
02-17-2020 09:45 AM
@kvbarkley wrote:Any USB type-mini-B cable should work. Just make sure it is not a charging cable.
Be careful; some of Canon's recent high-end cameras (7D2, 5D4, ...) use a cable that's micro-USB3 at the camera end.
B&H sells all forms of USB cables. All the ones I've bought there have worked fine.
02-17-2020 11:00 AM
is it a mini b or minic c usb
02-17-2020 11:14 AM - edited 02-17-2020 11:15 AM
I am not sure, I find conflicting info, in any case, it is not a mini-b
02-17-2020 09:40 AM - edited 02-17-2020 11:21 AM
90D is Micro-B and 1D X Mark II is USB-3.
Google before you purchase.
02-17-2020 11:15 AM
02-22-2020 04:28 PM - edited 02-22-2020 04:29 PM
On Canon's store, and th emanual, too, you can only find the number for the cable, no info as to what kind of connector it has. I believe it is just a micro-B, not USB-C.
02-22-2020 05:19 PM
@kvbarkley wrote:On Canon's store, and th emanual, too, you can only find the number for the cable, no info as to what kind of connector it has. I believe it is just a micro-B, not USB-C.
Which is exactly why I suggest a visit to B&H
You are correct, BTW.
