04-02-2021 05:54 AM
YEs I know Canondoes not reconize third party lenses- However please read thru this- I have a Tamron 18-400 lens that is 5 months old. This lens worked perfectly for the 5 months. NO wthe lens willnot focus at 200mm or above. I sent intheLens to
tamro- they retued in working ordere. no mention of a problem. Still des not work above 200mm. There are countless( and I mean lots of 90D owners on Facebook that use this lens- Now comes the real problem- This lens works fine on 4 different Canon bodies!! 7D MKII, 5Ti, 5D, another 90D( a friend). My 90 D works with 8 Canon Lens + another Tamron,a Tokina, and a samyang lens. I sent the body in for repairs to the tune of over #300 buck as it was out of warranty- It came backthe same way??? I don't think tey did anything to it as it worked with all Canon lenses??
Any one have any ideas what to try ??. It is a great walk around lens I can use it on my 7D MKII but the 90 D is much lighter and so I liket o use it on the 90D.
Thanks!
06-16-2021 06:28 AM
@steinr98 wrote:You may. be correct on tolerances... however this lens works on hundreds of 90Ds on facebook- and as I mentioned numerous times, this lens worked for 4-5 months on my 90D. A friend had this lens and I was completely surprised on how sharp it is! I blew up a few photos to 13 X 19 and they held their sharpness- Yes I reallize it is not a canon "L" series, however for a "Good" walk around lens it is super!
Thanks- I am beginnng to think it just a no go on this body-
Ron
Your lens is not their lens, and their lenses probably perform just as well on their 90D cameras as your lens does on yours.
I recommend resetting the camera back to factory defaults, and clear out any AFMA adjustments you might have made. Start over with a clean slate. You may have changed some setting that you may have forgotten about, which is negatively impacting performance.
Be sure to disable Face Recognition and iTR, too. You do not need those enabled for action photography.
06-16-2021 06:35 AM
@steinr98 wrote:I might add that when the 90D tries to focus it goes past focus and back again to a non focus spot. Actually a slow focus like it is dragging its feet!
Again, remember it focuses perfectly in Live view!!
I do not recommend an AFMA adjustment with this lens. It does not focus consistently accurate to be worth the trouble.
If the view through the viewfinder is totally out of focus, then the camera does not recognize anything to focus on. It might start "dragging its feet" because it is searching for something to focus on. Remember, the camera can only see what the lens shows it.
Also, the lens has a VERY WIDE zoom ratio. This does not help autofocusing.
06-16-2021 09:09 AM
The fairly narrow maximum aperture of this lens makes AF more difficult for the body, particularly in lower light. The maximum aperture of your lens is down to f5.6 around 90mm decreasing to f6.3 just a few mm later so most of the time the 90D AF system is hindered by this narrow aperture which will cause slower focusing and more hunting/seeking.
AFMA may help and I would calibrate the W and T settings for this zoom at your most used wide and tele ranges if you have favorite spots in the range, this may provide some improvement.
Good luck!
Rodger
06-18-2021 01:57 AM
Waddizzle: It does not matter what I focus on- I can do extreme contrast(this is one of the 90Ds problems) but it will not focus- again- deos it in live view. I did have one suggestionl that if I can go back to the orig firm ware It migh solve the
problem but would then lose my 24 fps video - uggg!
Thaks
06-18-2021 02:05 AM
Wq9nsc: Again... This lens worked perfectly with no problems at all for 4-5 months- it is a bummer- I mentioned earlier, the old firm ware may be the trick?? but again there R tons of people on Facebook with no problems.and I mean tons of people!
Thanks- I can't believe LiveV works- I have tried very bright light and contrast- made no difference! To darn hot out to do the AMFA at the momlent -I'm in AZ.. only 113 yesterday and near that today!!
Thanks!
06-18-2021 11:38 AM
We are still talking the, "I have a Tamron 18-400 lens that is 5 months old." lens? I kinda lost track with all the suggestions. Some good some not so good. It is very unlikely it has anything to do with the Canon FW so keep the version you have. Canon doesn't care or even know what a Tamron 18-400 lens is.
I would reset the 90D to factory just to be sure you didn't accidentally set something. Who knows. Also zero out a focus adjustment you may have made. The Tammy isn't the greatest lens made and is probably a slow focusing lens anyhow. But the slow and slower aperture isn't likely the culprit either. These lenses fool the camera by lying to it about f-stop.
I doubt there is any benefit sending the 90D to Canon for a service complaint about it not working with a Tamron lens. Your best bet is to contact Tamron and explain the problem. Tamron CS had improved a good deal in the past several years. From nonexistent to at least the OK level.
06-18-2021 01:46 PM
ebiggs1:
idid drest the 90D to Fasctory defauilt 2 Times- Bothe the can and Tamronlhave been back to the factorys- I can try dremoving the micro focusing andtry that- again wha tgeets me is the lens wodrks perfectly in Live View ??? The lens works perfectly on my 7D MKII. y copy of tghe 18-400 is prettydarngood a fast focus and extremely shaprp! It is a great walk aroud lens- tha tis why I'm trying to figure th is thing out!! I can try Tamron- Canon gave me no satisfaction as they do not care about 3drd party lenses.
Thanks!
06-18-2021 03:57 PM
"Canon gave me no satisfaction as they do not care about 3drd party lenses."
Now honestly did you actually expect them to? No company is going to help you use or operate a competitors product. You wouldn't if it were you.
It looks like you have run the course of suggestions from the forum users. It looks like we are not going to be able to help.
Just because it seems to work using LV and not the VF doesn't settle or confirm anything since the two systems are different.
All I can say is good luck with it and I do hope you find a solution.
06-18-2021 04:50 PM
I think you are correct- I am of the impression it may be a tolance thing( Canon's explination by one of the managers I spoke with) - who knows- I believe all avenues have been expored.
One other item that makes no sense to me is the multitude of 90D owners that use this lens, and also the fact this lens works on 5 different Canon bodeis where I live.
So, Thanks to all who have tried to help!!! It just isn't in ther cards!
Ron
03-22-2022 02:19 AM
You seem to be missing the possibility that the other camera is running an earlier firmware version that works with the Tamron lens and that a more recent firmware version does not work with the Tamron lens. I've had Canon cameras in the past that worked just fine with third party batteries (full compatibility - reading serial numbers, numbers of shots, percentage of charge left, etc.) until I updated the firmware and then suddenly the camera would no longer communicate with those third party batteries. Canon seems to love updating firmware to make third party products harder to use with Canon camera bodies.
