80D Video Settings
MikeV2013
The Lions Club to which I belong would like me to video tape our speakers. I am a long time still photographer, but have zero video knowledge. I am going to use an 80D, 24-70 f2.8, and Road mic. The meeting room holds about 100 people so it is not very large. I suspect the front row of lights will be off for the projector screen.I am thinking manual focus with maybe f8 for DOF.
Question, please give me a starting set of camera video settings with which to practice.
Can you please recommend a book, online tutorial/video that can get me up to spped rather quickly.
Thank you.
Mike
@MikeV2013 wrote:
Thank you for the videos. I can do the exposure/DOF settings pretty much in my head for stills with my regular cameras. Just not sure about frame rates, etc. for video. I took a practice shoot and am headed to Photoshop to see what I can do - learn Premier if I must. I just want to video a speaker not become a videographer. I am hoping the 24-70 f2.8 helps with the light issue.
I think any quality lens would be just fine for static shots.  It is when subjects begin to move about the frame, or when you begin to move the camera, is when things begin to get really complicated, really fast.  Set up a tripod, and let it run.  Do not forget about the 30 minute time limits.  You can also expect the camera to overheat after extended use in video mode.
I suggest using 24 fps frame rate, and a 1/50 sec shutter speed, which is equivalent to a 180 degree shutter angle.  This will give your video a ”cinema” look.  Faster frame rates will allow you to record in brighter light without the use of an ND filter.
Using higher frame rates will, of course, need faster shutter speeds.  But, the faster frame rates will not only create MUCH larger files for a given recording time, but the resulting videos may begin to take on a “video tape” look, due to a loss of motion blur in the individual frames.
Take a few stills of the venue, so that you can get an idea of what the light is like.  I have no idea what it is, so I can only offer rules of thumb, guidelines, and strategies.
Computing DOF in your head is pretty impressive.  I regularly refer to the table when I know light and DOF will be critical.  Given enough practice, I suppose that i could memorize enough of it with enough experience with the same lenses.
Canon has Movie Software that you can use, too. Not as good as PSE, but it is free.
14 REPLIES 14
kvbarkley
More light. Maybe a spot on the speaker.
One other thing to take into consideration.
Still camera will only record for 29 min and 59 sec.  before it shuts off. Be prepared and time your transitions accordingly.  The guys will think you're a real pro.
Cheers
Waddizzle
Put in some practice recording videos.  Have a couple of spare batteries and memory cards on hand.  You will need a “B” camera for the moments when your “A” camera stops for a memory or battery change, or for whatever reason.
Put in some practice recoding videos.
What camera settings do you recommend I start with?
No one can answer that for you.  This is exactly why I suggested that you get out and gain some practice and experience shooting video.  One thing is certain, though.  It really helps to be a good still photographer, who is familiar with the Exposure Triangle and Depth fo Field.  A strong familiarity with these concepts, most especially being able to calculate equivalent exposure settings, are essential for a videographer.
First and foremost, you will need to make a determination as to what recording frame rate you will want to use.  Shooting at the fastest frame rate will produce the largest files, which will take more time to edit.  Large files will also have their own set of issues on your memory card.
You would be surprised at how many major films and TV shows are shot at 24 fps: i.e.; Game of Thrones and Star Wars.  Fewer frames per second means less special visual effects frames per second that you would need to create.  Once you have a frame rate, you will want a shutter speed that is a multiple of the frame rate, preferrably twice the frame rate. You may want to look up “shutter angle” on Wikipedia.
Next, you will want to determine which one of the Creative shooting modes you will want to use.  Because you will want to have exact control over the shutter speed, the inclination is to use Tv mode.  Manual is what is best because you will want to have control of the aperture, instead of letting the camera control it in Tv mode.  Apertures can be noisy, so we may want to keep it fixed, at a constant setting.  ISO is a completely new headache, and one which you do want the camera to control.
How much available light you will have, and how it may change during the course of the recording sessions, can and will affect your exposure settings, most especially ISO and aperture.  Try to keep light constant, so that you do not have to worry about adjusting your aperture, or allowing the camera to do it automatically.  Try to keep the camera fixed on a tripod, instead of panning around, which can change the amount of light entering the camera, as well as introducing on th fly refocusing issues.  Set it, and forget it, if you can.
Again, practice makes perfect.  You can practice just by taking stills, but forcing yourself to use specific shutter speeds.  Of course, you will need a tripod for this.  You may even need a an ND filter, several ND filters, or a variable ND filter, because of the relatively slow shutter speeds used for most video.
You could always put mode dial in Greeen [A] mode, and then turn on Movie Mode.  But, if you have ever moved past shooting stills in Creative Modes, then you can imagine how unpredictable the videos could turn out.
If you think that I did not really answer your immediate question, then you would be correct.  I cannot answer it.  I can only point you in the right directions to figure it out for yourself.
Thank for the insights. I normally shoot manual. Just not quite sure how to make the transition to manual in video.
Put in some practice time.  I cannot stress this enough.  Learning to shoot video is more challenging than learning to shoot stills.  What exposure settings to use only scratches the surface!
How long will the entire video need to be?  Set the camera on a tripod.  Now try to record an entire video at the length that you expect that you will need.  If you can simulate the expected exposure settings, all the better.  But, exposure is not the point of this exercise.   Practice is the point.
You really need to learn how deep the well is going to be.  You need to get a feel of how many backup batteries and memory cards you might need....and then have double that number on hand at show time.  This is probably going to be the biggest nut that you will have to crack.
[EDIT]
BTW, the 80D is not a video camera.
While it can record video, it can only do so with a number of limitations.  Capturing long videos is not one of its’ strengths.  DSLRs are good at capturing short video clips.  Videographers combine the short clips into one longer, continuous video.
To capture a single video clip of extended length, you may find that a DSLR will NOT deliver what you need.  I fully expec that you may discover that you will need a camcorder for the task in front of you, not DSLR.  But, you will not know until you try it.
Waddizzle
@MikeV2013 wrote:
I suspect the front row of lights will be off for the projector screen.  I am thinking manual focus with maybe f8 for DOF.
Thank you.
Mike
I suspect that you will most Isley be “starved” for light.  Using f/8 would likely exacerbate the light problem.  Here are two links that I hope the moderators do not delete.  The first link is to a video with a low tech demonstrate of how to do exposure “math”.
https://youtu.be/WNpDL2FEUdI
He demonstrates how to estimate equivalent exposure settings.  Bear in mind that your shutter speeds will most likely be limited to much slower speeds than he uses in the video.  A videographer might want to have a fourth column, ND filter.  But, since you will be shooting in an environment that is likely to be starved for light, I doubt if you will need an ND filter.
The next is a link that I have posted many times before to Depth of Field calculator.
http://www.dofmaster.com/doftable.html
This is an old link, so th 80D wil not be listed.  But several older Canon APS-C bodies are listed, which have the same sensor size as the 80D.  You could use the default setting for the 7D.
Without knowing what focal length you would be using, I hope that you can see how it is impossible to offer an opinion on whether or not using f/8 is appropriate.  Hopefully, you can use this table to answer that question for yourself.
But, since you are a member of the club, then go into the meeting room and practice recording video.
