05-11-2018 06:53 PM
The built in flash on 80D pops up in Auto mode but won't fire. I put "built in flash on" in the on mode and it will pop up but not fire. I have been using 430EXIII RT and everything has been working fine. Been shooting in P mode and built in flash and 430 have been working well. Not sure if I have pressed the wrong button or what but I sure do need some help. Thanks in advance.
12-30-2018 09:02 PM
I am having the same problem. After 3 weeks use my flash stopped working. Tried the reset script with no luck. contacting canon next business day.
01-01-2019 05:14 AM
01-01-2019 10:51 AM - edited 01-01-2019 10:52 AM
Did you update the latest firmware 1.0.2 version ?
Cheers.
01-01-2019 12:25 PM
No I havent. Should I ?
01-01-2019 12:34 PM
Yes, you should.
Follow the update instruction carefully from Canon website.
Hope it will help after firmware updated.
01-01-2019 12:51 PM
01-01-2019 12:55 PM - edited 01-01-2019 12:58 PM
@tmc784 wrote:Did you update the latest firmware 1.0.2 version ?
Cheers.
@dynamix wrote:No I havent. Should I ?
First check to see what firmware your camera currently has. You may already have 1.0.2 installed. Early 80Ds had version 1.0.1 and there was a firmware update to 1.0.2 which would have been factory installed on later 80Ds.
@tmc784 wrote:Yes, you should.
If you are comfortable with the upgrade process, then go ahead, but there is nothing in 1.0.2 that would fix a flash problem.Firmware Version 1.0.2 incorporates the following improvement and fix:
- Improves the reliability of communication via USB cable when using the Lens Data Registration function within EOS Utility 3 software.
- Fixes incorrect indications in the Norwegian menu screens.
01-01-2019 12:58 PM
01-01-2019 01:07 PM
Send it Canon for service because there is obviously something wrong and there is no way to fix it yourself.
03-31-2020 09:29 AM
It's a shame such a good camera has a problem like thius. Mine was repaired twice and seems to be repaired. Has worked for about four months now. The "Flash cover" is what I was told was the problem. Mine was under warranty and was repaired at no cost.
