11-15-2012 09:45 PM - edited 03-20-2013 11:13 AM
Can't afford the 5d mk3
Can afford a used 5d mk2 but not sure i am very happy with 9 AF points plus the slower frames per second then the 7d
Why are so many people selling there 7d and buying the 5d mk2 ?
03-20-2013 09:32 AM
I think your comparison is a little off when comparing to real world uses.
What you need to do is take a photo with the 5D and 100mm lens and than the same with the 7D and 100mm lens.
Now you need to leave the 7D photo alone and enlarge the 5D photo so the "subject" is the same size as the 7D's.
The 7D wins every time.
This apparent advantage in crop factor is why "Birder's" use and love the 7D and 1D Mk III and IV's.
03-20-2013 09:34 AM
I believe the "Birders" and other wildlife photographers are keeping the value of used Mk IV's up since it is likely the last 1.3 crop Canon.
03-20-2013 10:11 AM
@ebiggs1 wrote:I think your comparison is a little off when comparing to real world uses.
I did just that. Both taken with the same exact lens, same subject, same distance, same settings, etc. 7D is as it came from the camera. 5D is cropped to 1.6x. Both images are then resized to the same size. (Unfortunately downwards, as there were a file size limit for uploading picture here.) If you'll notice I even wrote the resulting pixels sizes during the steps.
However, when you crop the 5D image to 1.6x, the pixel dimensions are much smaller than that of 7D, although both images cover the same area.
Perhaps I should have resized the images according to per centage instead of both to the same size.
03-21-2013 08:25 AM - edited 03-21-2013 08:28 AM
Here is a comparison between a 7D and a 5D3.
Subject was the same distnace from the camera and shot with the same 100/2.8 L Macro lens.
Resulting images have been enlarged (to roughly the same size, using LR zoom slider) to show the real difference in resolution more clearly. 5D3 on the left, 7D on the right.
As you can see, the 7D resolves more detail from the same projected image. This is reach - and the 18MP crops are still the highest resolving DSLR's in the Canon lineup. And this is part of the reason why the 7D is so valued by birders.
(BTW - make sure you view this image at it's full size to see the difference properly. Right-click and select Open Image in New Tab)
03-21-2013 08:53 AM
03-21-2013 11:08 AM - edited 03-21-2013 11:09 AM
There is no need to delete your question as other folks probably have the same question and would like to see the results and answers. It will benefit people besides yourself.
You are having issues with lighting using the 7D and the 70-200mm f2,8 Mk II lens in a basketball gym? That surprises me as I do the same thing and I don't notice it. Ours maybe better lighted, I guess.
03-21-2013 11:14 AM
Well like I say the lighting is questionable but exceptable. I just would not want to print these any larger than st 5x7
03-21-2013 12:14 PM
Make sure you are not your own worst critic!
03-22-2013 04:16 AM
That was a really good comparison. Thank you for the effort, schmegg.
