09-03-2017 03:29 PM
I was changing a lot of settings on my camera.
I use it in TV mode and after my changes and going back to TV mode my iOS will not stay at 400 or whatever I set it on. It changes to 6400 or 3200 or... depending on the lighting. I cannot contact Canon support as it is a holiday.
I was hoping someone could tell me what I have done.
At first I thought it was because I left my white balance on cloudy day. But I changed that back to auto and it still changes my iOS settings. I know I'm missing something I just can't figure out what.
09-04-2017 12:00 PM
Press menu, go to 5th group from left (camera with dots under), select safety shift and turn it off (disable). It looks as though you have got it set to ISO at the moment.
09-03-2017 03:46 PM
You have most likely set it to AUTO ISO in a menu.
09-03-2017 03:49 PM
It sounds as though you may have set it to auto ISO, if this is the case then you will see the letter A on the top LCD.
09-03-2017 03:51 PM
No letter A :smiley frustrated
09-03-2017 04:05 PM
I'm thinking in one of the menu items rather that in the normal ISO setting method.
09-04-2017 02:03 PM
@MabelLucy wrote:No letter A :smiley frustrated
That does not necessarily mean that ISO is not set to AUTO. If the metering is active, you will see an ISO setting.
If you press the [Q] button, for Quick Menu, you should see the exposure and camera settings. If ISO is set to AUTO, you will always see it on this screen.
09-04-2017 12:00 PM
09-04-2017 12:22 PM
Just to be pedantic:
iOS = iPhone Operating System
ISO = International Standards Organisation
09-04-2017 04:45 PM - edited 09-04-2017 04:46 PM
I found that and it took several tries to get the right combination.
You were right, I had it set on ISO. It is now set to Tv/Av and I think I am happy.
Thank you.
