05-06-2017 08:53 PM
First: I am in I.T.. I have Googled & Binged many troubleshooting options, including all possible "turn it off & back on", "plug it into another port", & "reinstall the driver" (yes, there is a driver: the MTP driver). I am on Windows 10 (everything on newest updates)
The camera is simply not there. It doesn't appear in Explorer, none of the software (Bridge, EOS Utility, Lightroom, etc) recognizes that it exists at all. It was working fine, but I joined my work domain which requires making a new user account. After that, nothing. I can't even get the EOS Utility to recognize it over WiFi anymore (that might be due to the domain join, but wired connect should work).
I have tried everythig I can find, including this little nugget: http://bit.ly/2pSeTJl
Please send help & coffee! 😉
02-02-2018 03:26 PM
02-12-2018 07:59 AM
I was having the same problem. I would connect and turn the camera on. It would connect but only momentarily and never show up in the file explorer. I uninstalled the camera and then turned it back on and it was then visible to file explorer and stays connected. Hope this helps someone.
03-06-2018 10:39 AM
No need to install Canon Utility for a windows computer to recognize the camera. You should be able to see it and copy or drag and drop files using windows explorer, but if you have windows set to take no action, you may not see anything happening as you connect it. facebook Apk
If it doesn't work with Canon utilities installed, try a different USB cable, and port on the computer. Don't to forget the old faithful solution, reboot the computer --- it still sometimes works
1. The camera is not connected properly to the computer with the USB cable
2. The camera is not recognized by EOS Utility (You can only click [Monitor Folder] on the main window of EOS Utility)
3. CameraWindow is being used
NOTEIf your computer does not meet the System Requirements for EOS Utility, you can import images using a card slot on the computer or a commercially available card reader.For the procedures for importing images using a card reader or a card slot on a computer, please see the 'Related Information' section at the end of the page.
4. The camera is not recognized by Windows OS
03-25-2018 01:18 PM
I have had the same problem.
I took the WiFi card out of the camera and hey presto it now works. Connects lovely to the camera via USB.
03-25-2018 01:22 PM
@damgoodwrote:First: I am in I.T.. I have Googled & Binged many troubleshooting options, including all possible "turn it off & back on", "plug it into another port", & "reinstall the driver" (yes, there is a driver: the MTP driver). I am on Windows 10 (everything on newest updates)
03-25-2018 01:25 PM
@BillinTexaswrote:I was having the same problem. I would connect and turn the camera on. It would connect but only momentarily and never show up in the file explorer. I uninstalled the camera and then turned it back on and it was then visible to file explorer and stays connected. Hope this helps someone.
Take out the WiFi card and all will be well.
03-25-2018 02:19 PM
09-01-2019 11:52 PM - edited 09-02-2019 12:01 AM
I feel your pain. I have a 7D and the 7D mark 2. The 7D is recognised by Windows 10 on my PC and Windows 7 Pro on my Laptop. The 7D mark 2 is only recognised on my Windpws 7 Laptop and NOT my Windows 10 PC. Same cables as supplied with each camera, same USB ports. Does Canon have an answer or do I go to Microsoft?
I have set my autoplay to "Ask me every Time" and all the other options as well. Also in the autoplay list of All Media & Devices, I see the 7D and 2 entries for the 7D mark 2!. I'm begining to think there is no resolution to this problem. I have not found a remedy that works so far. I am only using the CF card and don't use the WiFi card supplied with the camera.
I hear the 4 beeps tune when I connect the camera and the 3 beep tune when I disconnect the cammera, but no ther action is noticed. My main reason nfor wanting the 7D mark 2 to be recognised by Windows 10 is, I use a great software program to read the shutter count, as Canon insists that this is be a secret - why? I don't know - other camera makes give easy access to this information and even include it their image EXIF data. Can anyone help?
09-02-2019 07:39 AM
Try manually starting the EOS Utility 3 for the 7D Mark II.
09-03-2019 04:06 AM
I uninstalled ALL canon software because I don't want to use it. Windows 10 should be able to recognise the 7D2 as soon as it's connected via the supplied USB cable. Are you suggesting Windows 10 will only recognise the 7D2 if I have EOS Utility 3 installed?
