04-24-2014 06:52 PM
On my 70d can I change a setting to clean up the hdmi out, I want to remove the gray box and black letter box so that the image fills the full screen.
04-24-2014 11:36 PM
04-25-2014 08:04 AM
Sometimes I have the same problem with the additional info being displayed on the screen while hooked up to an HDMI TV. Pressing the DISP button didn't seem to work.
I found that if I disconnected the HDMI cable and then pressed the DISP button to clear the info, it would then be Okay once I hooked it up again.
There is probably a simpler way to do it, but that works for me.
04-25-2014 02:54 PM
hsbn and MikeSowsun:
I was able to get all the extra info off by hitting the display button, the issue is the letter box. Using teh zoom fucntion on the TV should solve that problem for the TV, but I was hoping that I coudl remove the letter box from the feed because what I really want to do is read the feed into wirecast (via a black magic ultrastudio mini recorder) and use it for a live streaming broadcast.
It doesn;t see like there is a way to turn off the letter boxing in the camera, or is there???
04-25-2014 03:17 PM - edited 04-25-2014 03:44 PM
I don't know what you mean by "letter box". When I hook up my 5D3 or SL1 to my 60" Samsung TV, and play back a video, I get a full screen display with no text, or anything else.
04-25-2014 03:25 PM
04-25-2014 03:28 PM
it looks like this (only without the time stamp)
04-25-2014 03:31 PM
Here's another screen shot:
the image should fill all the black- no gray line, no letter box. At least that;s what I want.
t
04-25-2014 03:41 PM - edited 04-25-2014 03:43 PM
I think I see what you mean....
With my SL1 I see a gray box and blacked out area when hooked up and recording video. My 5D3 doesn't do this....
On playback they are both full screen.
Is that what you mean?
04-25-2014 03:43 PM
yes thats what i mean—if I can remove that letter box I can make my 70d a low cost very hi quality studio camera for a webcast.
