03-09-2019 07:33 PM
Hello,
I have been using my 70D for over a year now but only recently have I discovered the use of shooting in raw. My question has two parts:
1) Which raw setting should I choose? RAW, MRAW or SRAW? What is the difference/purpose of each? File size?
2) When I take a photo and wait to take another my camera "goes to sleep" when I "wake it back up" (pardon my ignorance) then the raw settings disappear and it goes back to shooting just jpegs. Any ideas on how to fix this?
Thank you!
Sirrina
03-10-2019 01:24 AM
Sirrina,
The purpose of the different RAW types is to give the user options based on resolution/ output requirements and size constraints. So for example, if you know space might be limited but still need an uncompressed image then one might select the medium RAW setting or small RAW setting for web output. What you pick is dependent upon your specific shooting style and needs. RAW files are 20 MP 5472x3648, M RAW are 11 MP 4104x2736 and S RAW are 5 MP 2436x1824.
There is another thread that goes over how to register custom settings into the camera to avoid being lost.
https://community.usa.canon.com/t5/EOS/Canon-EOS-70D-Loses-Its-Settings-On-Restart/td-p/206753
03-10-2019 10:53 AM
Straight RAW is the most compatible with third party RAW processors.
03-10-2019 11:01 AM
The above link doesn't work, for some reason it appends %A0%A0 on to the end of the link as shown.
03-10-2019 11:10 AM
@Sirrina wrote:Hello,
Thank you!
Sirrina
What shooting mode are you using? Are you using a Custom Shooting mode? When you register a custom shooting mode, there is an option to enable or disable automatically updating the shooting mode with your changes to the settings.
03-10-2019 01:02 PM - edited 03-11-2019 10:54 AM
The answer to number 1 is always shoot full size Raw. If size is a concern you need to make sure you have enough storage space. Small Raw files defeat the purpose of a Raw file. It is sorta like those water saving faucets for taking a shower. Yeah you get wet but thats it.
Numer 2, you need to reset the camera to factory. If that doesn't work call Canon 1 (800) 652-2666
03-10-2019 10:54 PM
If I recall correctly, shooting anything but a full size RAW file limited some of the image adjustments you could make in DPP4. It seemed like it was only the RAW adjustments that you could make in-camera, at least with my 60D. And I'm only guessing that other Canon DSLRs operate similarly.
Full size RAW files are the only way to go.
