10-14-2016 02:52 PM
10-15-2016 12:36 PM
"Question: Could a high humidity environment cause a problem with the connectors between the body and the lens?"
It never has for me and I have shot things is pretty difficult places in my 40+ years of photography. I shot in hurricane Ivan where the gear was wet. Not just humid, I would say101% humidity. ![]()
10-15-2016 02:29 PM
@ebiggs1 wrote:"Question: Could a high humidity environment cause a problem with the connectors between the body and the lens?"
Canon DSLR camera bodies are typically rated at 0-85% humidity, which I would assume describes storage conditions.
10-15-2016 02:54 PM
10-16-2016 10:50 AM
"Canon DSLR camera bodies are typically rated at 0-85% humidity ..."
So....................?
You just stick with those specs and you will miss a lot of good shots. My gear does what I want it to. I have never babied my stuff. It goes where I go and does what I do.
10-16-2016 11:13 AM - edited 10-16-2016 11:15 AM
@ebiggs1 wrote:"Canon DSLR camera bodies are typically rated at 0-85% humidity ..."
Good, for you. I believe that the OP was speaking about storage conditions, not usage, and so was I, and so was Canon's spec.
10-16-2016 11:27 AM
" I believe that the OP was speaking about storage conditions ..."
Doesn't matter my gear goes where I go. It is stored where I am. No special consideration is given to it over where I happen to be. I have five cameras sitting right here on my computer desk right now. I use my cameras on a daily basis so there is no time for special storage considerations.
