03-10-2013 12:12 AM - edited 03-10-2013 12:13 AM
I took some pictures at ISO >25600 and found a lightspot down in the right corner. I am wondering why just one corner? It is not like the 5DIII:s light leak, because this will appeare in a dark room and always in the same corner. Is it warmer in that corner and results in more noise?
http://imageshack.us/photo/my-images/233/img0605rr.jpg/
It is not a real problem, but I am curious.
03-13-2013 06:29 AM
Hi Peter,
I would like to ask a few questions about this if you do not mind.
03-13-2013 07:00 AM
I am just wondering why just one corner will light up. I will try some new shots.
03-13-2013 07:10 AM - edited 03-13-2013 07:29 AM
Okey, here we go:
Raw image you find here: http://kameratrollet.se/allt/6d.CR2
I tried 4 seconds at different ISO. Only at H1 and H2 the light in the right corner appears. I suppose the sensor is warmer in that corner than in other places, so my question is why?
I don´t think I will use H1 and H2 at all, but I am curious.
http://kameratrollet.se/allt/6d2.CR2 shows a picture that is taken at H2 and 1/800 seconds. the right corner is lighted up.
Noise reduction for long expsure will remove the lighted corner, but only for pictures with longer exposure than 1-4 seconds.
08-12-2013 12:37 PM
02-10-2014 02:15 PM
02-10-2014 03:21 PM
It may not be a "leak" at all.
When you crank the ISO really high, you get a lot of noise in the image -- you already knew that. But there is a relationship between the physical temperature of the chip and the amount of "noise". You also notice the pattern noise (and that's normal -- all sensors do it). If you were to chill the camera by being outside with it an hour or so, then repeat the same test and compare the images, you'd notice that the images taken wtih a very cold sensor have noticeably less noise than the images taken with a warm sensor. The opposite is also true -- if the camera is used in very hot temperatures then it will have a lot more noise in the image.
I'm wondering if your sensor wasn't simply "physically" warmer in that corner, making it have more noise.
02-11-2014 04:18 AM
Maybe it is. The only question I have left is why we haven't seen the same thing from other models from Canon.
02-11-2014 09:55 AM
The only explanation is Canon rushed to build a cheap full frame to compete with D600. They squeezed every corner and saved every penny on quality control.
