08-18-2014 03:30 AM - edited 08-18-2014 03:40 AM
Hello,
I have had my 60D for over a year now, and have no problems with it what so ever. That is until last week in the middle of a shoot (I use mine mainly for film), my screen went black. It wouldn't respond to anything, you can't use play back or bring up the menu. NOTHING. I've read/tried every solution I could find on the web, taking out the battery, using a different SD card, read through the manual several times etc. I will point out I haven't found anyone whose had this specific problem. I initially thought that there was some sort of loose connection with the screen itself as it seems it still records video and can still take pictures.
However when having another attempt to sort it out I found out that if you gently hold down the shutter button the screen comes on ( but you have to keep your finger there) but you can't use any of the other camera features such as recording, using the menu or playback etc So surely that means it’s not a fault with the camera itself and maybe a firmware issue?
Has anyone else had this problem or know a way to solve it? It's driving me Insane!
If it makes the diagnosis any easier I could make a video of my problem and post it to Youtube.
Thanks,
Olver Jones
08-18-2014 07:51 AM
@oliver_jones wrote:Hello,
Thanks,
Olver Jones
It's hard to see it as a firmware issue unless you recently upgraded the firmware. It certainly sounds as though some connection (in the camera) has worked loose and become flaky. Until you send it into the shop, I suspect you're just wasting your time.
They'll look first at the shutter button assembly, because of the symptoms you describe. And the fact that the shutter button is used all the time makes it plausible that that's where the loose connection is. In and out in a day or two, most likely.
08-19-2014 01:36 AM
Yeah I'm going to send it in to be fixed. Thank you
