10-16-2015 10:58 AM
My 60d doesn't take picture with my infrared remote anymore. Worked just fine for two photo shoots a month ago and now it won't work at all. I purchased a new battery for the remote thinking that was the issue and still nothing. I then bought a new remote and still nothing. I have the camera set on the timer/remote setting just like I did before but it doesn't event flinch when I push the button on the remote. Any ideas?
11-23-2016 06:10 PM
@lowrider wrote:Thanks for the responses.
I have tried tried to clean the sensor on the hand grip, but there's no difference.
Neither of the two remotes I have work (one of which is brand new), and both have been tried with new batteries.
I am at a loss.
Did you see Tim's suggestion? Check the shooting mode of the camera. It must be in timer mode. By requiring that the camera be in timer mode, which is seldom for the average user, the shutter will not be triggered by a stray IR signal.
11-23-2016 06:36 PM
Hi Waddizzle, thanks for the message. Yes, I've tried the remote settings, both the 2 second, and the 10 second setting. I've also tried each setting on the remote control, but no response. It used to work perfectly, and I know how to use it - though I havn't used it for a while. Strange.
11-23-2016 07:19 PM
try reset in the menu :
Clear all camera settings
Clear all custom Funct. (C.fn)
11-27-2016 07:47 AM
Hello, Thanks again for the message and suggestions. I have now cleared all the settings, both in the 'all camera settings', and the 'camera user settings'. Still no response from either of the remote controls 😞
11-27-2016 09:50 AM
@lowrider wrote:Hello, Thanks again for the message and suggestions. I have now cleared all the settings, both in the 'all camera settings', and the 'camera user settings'. Still no response from either of the remote controls 😞
It seems like the camera's sensor has failed. I would contact Canon Support, and see what they say about it.
11-27-2016 01:11 PM
If you need the wireless remote feature, you may order one online for as low as US$15. Otherwise, expect to pay over $200 to have it repaired by Canon.
05-02-2018 11:30 AM
Has this issue been resolved. My IR stopped working. I have used IR for on my 60D for many years so I know how to use it and what camera setting to use. Worked one day and stopped working the next.
05-02-2018 02:13 PM
To prove that the remote is sending a signal point at your phone camera or almost any digital camera and press a button on the remote control, it will need to be very close and preferably in a darkened room. A digital camera can see the infra red light and you will be able see it flash dimly.
05-02-2018 02:31 PM
I use my remote at night when taking photos of the moon so it is very dark when I use it.
I have the remote 3 to 6 inches from the sensor.
05-03-2018 10:53 AM
I don't think you understood my last post, the operation I described will enable you to see if there is any IR light coming out of the remote control. If there is then you know the remote control is working and the fault must be in the camera. I was not talking about the conditions when you use the remote control to operate the camera.
