12-08-2013 07:04 PM
On my 5d mark iii, i can only see where the autofocus points are, but not which ones are focused. Is there a way to see which points are in focus?
12-11-2013 11:50 PM
On the "AF display during focus" you might want to swtich it to "Selected (Constant)".
"Selected (Focused)" says they will only light up briefly to show you what it picked once it finishes focusing, but they go off immediately. The "Selected (Constant)" mode leaves them on.
12-08-2013 08:08 PM
What modes are you testing this in? I do see the focus points (and they track) on mine.
12-11-2013 02:53 PM
In Av, tv and manual (may be others too except I don't use them so I don't know or care), you select the focus points so what you see are the ones they are focused on. In the selection, there is an option for using all focus points, there you will see the ones that will be used for focusing highlighted. In full auto (the green A+), you will see the focused points also.
12-11-2013 11:21 PM
The modes I use are AV TV M. The AF display during focus is set at "Selected (focused)". When I half-depress the shutter button the black focus points all briefly light up together (red) - even when I know the whole scene could not possibly be in focus. I'm sure I must have one of the AF settings messed up.
12-11-2013 11:25 PM
I just switched from M to full auto, and the focused points light up, as expected. So I'm guessing the problem is something to do with how i have set the focus points. Will look for a tutorial. Thanks!
12-11-2013 11:50 PM
