5R mark ii wifi issues
Deeps1
I've just upgraded from the 5D mark4 and I my camera cannot find any wifi networks other than 2.4g
I have the Asus mesh with the main router being a BE98. So I have wifi 6 and 7. I've tried creating a separate network with 5g and 6g but it still does not see it.
What am I doing wrong?
4 REPLIES 4
Stephen
Moderator
Moderator
Your camera is compatible with 2.4 GHz, 5.0 GHz, and 6 GHz Wi-Fi:
From the product page on our site:
Also in the spec sheet, it says it supports the below frequencies and bands:
For 6 GHz, it specifies that the Authentication must be WPA3:
Deeps1
Thanks my settings are correct. Even if i try and manually add the wifi name it does not work. I will try with the wifi router my network gave me and see if it picks that up.
Do you happen to have it set to not broadcast your SSID? Some routers do that by default—for security.
No it's broadcasting
It also doesn't pick up my isp wifi.
Only 2.4ghz
