05-25-2020 10:38 AM
05-25-2020 11:41 AM
You are welcome and Standard is the preferred style as default, this is the style Canon typically uses to provide their camera burst/maximum file rated performance in RAW. I turn off all of the options (NR, lens correction, etc.) in camera and use those as needed during post to save time/battery life.
Again, I am not familiar with the 5DIV but I suspect scene intelligent is also choosing what it thinks is the best AF servo "case" when in servo mode which may be a better choice than the default Servo AF parameter setup (Case 1 unless you changed it)
Rodger
05-25-2020 01:40 PM
While the RAW has more lattitude, if you use DPP, Canon should apply the JPEG settings to the RAW as a first-pass rendering.
