09-03-2015 12:38 PM
Hi, guys, we've been having an ongoing issue with our 5DMK3 cameras and over the course of three years, this same issue has happened multiple times with all three of our 5DMK3 bodies. My main body has had this occur three times in the last four months; May 12, July 23 and Aug 30.
You click the link to see samples but it appears that the processor is compiling portions of multiple images into one corrupt frame. Canon CPS has replaced the CPU in two of the bodies, reset-updated firmware, but the issue continues to happen.
We regularly maintain our cameras at CPS and are using brand new SanDisk Extreme cards purchased in July 2015.
We record MRAW to SD and CF cards in manual mode, silent shutter mode, single shot, and the images are on both cards. As part of our back up protocol, we remove the CF card to take to the studio and leave the SD card in the camera, and you can see the corrupt image on the back of the camera before card was removed from camera so the issue isn't with our import process or computer.
Has anyone else had this happen and if so, what was the remedy, other than switch to Nikon? 😄
Thanks a ton for your perspective
09-03-2015 12:40 PM
09-03-2015 04:34 PM
09-03-2015 04:35 PM
@ronrandle wrote:Hi, guys, we've been having an ongoing issue with our 5DMK3 cameras and over the course of three years, this same issue has happened multiple times with all three of our 5DMK3 bodies. My main body has had this occur three times in the last four months; May 12, July 23 and Aug 30.
I would suspect that the issue is in the use of MRAW.
I don't believe Nikon has an equivelent to MRAW, so switching to Nikon, instead of simply shooting RAW would be a silly solution.
09-03-2015 04:46 PM
09-03-2015 04:48 PM
09-03-2015 04:49 PM
09-03-2015 04:52 PM
@ronrandle wrote:
TTMartin, thanks for the reply, that may be a possibility but we switched to MRAW this year and previous issues were shot in RAW.
From your research has anyone experienced the issue shooting RAW + JPG?
09-03-2015 04:58 PM
09-03-2015 05:02 PM
@ronrandle wrote:
It seems to happen in RAW and MRAW. We do our culling in PhotoMechanic and the embedded jpg previews are also affected.
The reason I suggested RAW + JPG, since you thought it was a processing error, having it produce a full JPG image at the time of shooting, might involve different processing of the image and be a work around.
