08-25-2014 01:51 PM
I recently inserted a CF card into slot 1, but the camera cannot see it or format it.
I've tried two known, good, error free CF cards, but the camera just tells me they cannot be accessed and to change them or format them in camera.
I've checked for bent pins in the slot, but they seem ok from what I can see. I contacted Canon Support who told me to revert all camera settings to factory default, which I did, but it failed to solve the issue. Failing that they advised to have the camera checked at a Canon Service Centre. The problem is I'm currently living and working in a country that doesn't have a service centre. I can't afford the downtime involved in sending it to another country to be repaired, so I wondered if any other Mark III users had come across a similar issue and solved it without the need of a service centre?
The SD cards still work, so all is not lost, but I'd like the option to use the CF cards, particularly for high speed shooting, which they seem to handle better than SD cards.
Any tips, suggestions, ideas welcomed.
Mant Thanks
Phil
08-25-2014 07:05 PM
I had a similar problem in that the 5d mkiii did not see one of my cf cards. I erased it with the computer and then reinserted the card into the camera. It recognized it then, but just be safe, I formated it several times using the camera menu. It seems to work now.. Try erasing it on the computer.
08-25-2014 08:16 PM
08-26-2014 02:10 AM
Unfortunately, no luck with this. Many thanks for the suggestion though, barrisster.
08-26-2014 02:13 AM
Thanks JoeN. I've tried with just the CF card installed, but as sson as I power up the camera I get the message that the card in slot 1 is not accessible. Replace or format in camera. I suspect this is an issue that only a Canon Service Centre can resolve.
Poor show for a supposed high end camera..!
Thanks Again.
09-03-2014
09:55 AM
10:01 AM
Well, Canon 'Technical Support' have been of no use. Sadly, I'm currently in a country that doesn't have a Canon Service Centre, and having done a bit of research it seems a few other Mrk III users have had the same issue as me, all of which needed a replacement body or a repair to solve the problem.
Poor show Canon. Top dollar for a 'professional' camera that can't even cope with the most basic of memory card formats.
Anyone recommend a reliable Nikon??
09-03-2014 10:55 AM
I suspect a bent pin. Unfortunately it is very difficult to see the pins at the bottom of the CF card slot. But a strong light source might let you confirm their condition definitively, something it appears you have not yet been able to do.
Barring the bent pin, I think you need to rely on SD cards until you're able to have the camera serviced.
Finally, you might feel abandoned by Canon but you have taken the camera to a location where it can not be serviced to your satisfaction. That sounds more like your choice than Canon's faliure. I am certain they would offer prompt service were you to send the camera in. At least, that has been my experience and that of others that have posted here.
Good luck.
09-03-2014 11:50 AM
Hi Cale_Kat,
I've used a flashlight and magnifying glass, and as far as I can see the pins look ok.
I spoke to a local professional photographer who gave the address of a place that turned out to be a Canon approved repair centre here. I've just back from there. They said 3-4 days to investigate and hopefully repair.
My dissatisfaction with Canon tech support is not the lack of service centres. I fully appreciate they can't have one in every country. My complaint is the lack of knowledge of my problem. I got more potential fix ideas just surfing the net than I did from Canon. As I'm not the only person to have had this problem, the least I would have expected from the manufacturer is a list of things to try, or even a blunt but simple 'your camera needs to be returned for repair'.
I've never had a problem with any Canon product I've owned in the past, which is testimony to the quality of the products they produce, and I'm sure they do offer a prompt service when you're fortunate enough to be somewhere where they have a service centre, but as I travel extensively, quite often my only line of enquiry for any tech related problem is a tech support line. In this case I just don't think Canon offered anything close to an effective level of support.
Anyway, I will see what the approved repair centre says when they've had chance to check it out.
Thanks for your reply cale_kat. This forum is a very good source for Canon users and I appreciate your input. If I get to find out what the issue is with my camera I will be sure to post a reply for the benefit of any other users.
Thanks
Phil
09-03-2014 03:50 PM
I'm glad you're making progress towards getting your camera repaired. The CF slot is an interface that gets too little attention for its importance, probably because it is has worked reliably for a long time. But there have been a number of posts at this forum regarding CF read errors. Sometimes it is the card and sometimes it is the camera.
If you are reasonably certain that the camera does not have a bent or broken pin, you might try buying/borrowing a different card for the purpose of eliminating your existing cards from the problem. I know you wrote that the cards are known to be good and I can appreciate that my suggestion may seem wasteful of your time but while I have no idea of what caused this problem, I can surmise that if one card is "damaged" it is possible that the other card is damaged too. Heat, cold and humidity can impact memory card performance, magnetic fields can be damaging, and there are other "environmental" factors that you might have encountered.
It's a stretch but I'll bet one of the first things the repair center tries is a CF card of theirs to see if it works.
Good luck.
09-04-2014 12:41 AM
That's a good idea regarding the cards, but unfortunately I haven't been able to test them in another camera or get my hands on another card to try.
The camera is booked in for next Monday, so hopefully all will be revealed.
I actually prefer CF cards to SD cards. Something about the chunky little fellows that appeals to me 🙂
Anyway, I'll post the findings of the service centre next week.
Thanks again.
