59.94 greyed out
mjgod
Hello all!
This is my first post here. Glad to be a member of the community.
I wanted to shoot at 59.94fps with by canon 80D but this option  is greyed out and I don't know why. Is it because of some other settings?
thanks
15 REPLIES 15
RAW for photos, but not video.
Ricky
Camera: EOS 5D IV, EF 50mm f/1.2L, EF 135mm f/2L
Oh, I see.
Thanks a lot for all the info in such a small amount of time!
Dmc233
I have the eos RP and im facing the same issue. Updated firmware. Cards write 90mb/s help please
Hi Dmc233,
Thanks for checking in with us.
I suggest that you check what resolution you are using on your EOS RP. The camera won't be able to shoot at 60 fps when the camera is set to shoot 4K resolution. You can check this in MENU - MOVIE REC. SIZE.
When shooting a time-lapse movie, you will also not be able to shoot at 60 fps, so make sure that feature is disabled, and try doing additional tests.
Dmc233
Gee thanks Nick.....totally couldnt have done it without you...thats not my issue bud..
Have you tried the previous suggestions in this thread?
Is your camera set for NTSC or PAL?
Avatar
