05-17-2020 10:19 PM - edited 05-17-2020 11:56 PM
Wondering if I'm doing something wrong.
EOS M50
When I record a video in (4K 23.98P) the video is zoomed way in compared to (FHD 59.94P)
I feel like maybe 40% magnified if that makes sense. loosing alot of the scene, I need to move way back to get the entire scene.
Or is this normal behavior?
Thanks.
Both pics below were shot at the same distance at 15.
05-18-2020 12:03 AM
I would guess so. Use an ultra-wide angle lens if you want to use 4K mode. I think Full HD is sufficient for 99.99% of the time, and far easier to edit. If you really need 4K video that much, you should be invested in areal 4K video camera.
05-18-2020 08:48 AM
Most DSLRs and even some cinema cameras will not read the entire sensor when recording certain resolutions/frame-rates.
If you need a partcular resolution to stay framed the same way (e.g. you have multiple cams; A, B, etc.), you'll want to look into the appropriate equipment. e.g. cinema cameras that would all use S35 sensors and read out the entire sensor. Or, full-frame cameras that would all crop the same way.
Otherwise, what Waddizzle points out as a workaround is solid. You'll have to use wider lenses when you cannot physically back up further from your subjects.
05-18-2020 10:27 AM
Use this reference:
To confirm what Wadizzle and rs-eos "Ricky" has already said. What you see will be affected by the FOV of the lens since 4K is shot from a cropped portion in the center of the sensor.
05-18-2020 12:03 AM
05-18-2020 08:48 AM
05-18-2020 10:27 AM
Use this reference:
05-19-2020 02:58 PM - edited 05-19-2020 10:39 PM
Thank you all, this makes perfect sense.
I'm glad I purchased the camera with the extra zoom lens.
EDIT: Actually what I said above makes no sense, lol..
05-20-2020 05:07 PM
Just for the record, the new 90D can shoot 4K "cropped" or "uncropped".
