04-05-2014 05:59 AM
would it be good to buy a 18-135mm F3.5-5.6) IS + a 70-300mm F4-5.6 IS both for my Canon 70D?
Or a 18-135mm F3.5-5.6) IS + a 55-250mm F4-5.6 IS STM?
Or with a 70-200? but then budget increases too much.
what do you recommend me? i want to have fun soooon taking pictures toi animals in Sri Lanka. Later i would pick a macro to take photo to insects when i do bike trails and also the Telescopic that i should choose.
04-06-2014 10:16 AM
The 18-135 STM and 55-250 STM would make a nice kit for the 70D. The 18-55 STM and 55-250 STM would also work well but would require you to changes lenses more often.
I recommend the 55-250mm IS STM over the 55-250mm IS or IS II because it is sharper and has a non-rotating front element. This also applies to the 18-55 versions.
I would not recommend the70-300mm IS because it is an older design with Micro-USM autofocus and a rotating front element which can be frustrating when using polarizing filters. The 55-250mm IS STM is sharper than the 70-300mm IS and the STM autofocus is both faster and quieter than the AF used in the 70-300mm.
If you can afford it, the 70-200mm L or 70-300mm L lenses are even better.
04-07-2014 05:54 PM
The lenses you mentioned are fine, actually very good, for the vast majority of amature photograhpers.
The lens I suggested is a step up lens. And the "L" lens I recommended is a full on professional lens. The best that Canon makes.
You will be more than happy with your original selection. Go make some beautiful pictures!
04-09-2014 06:07 AM
Last question!
Which Makro lenses would you me recommend? I don't know much about it.
THanks
04-09-2014 10:14 AM
The Canon EF 100mm f/2.8 Macro USM Lens, with out doubt a best-buy!
04-09-2014 10:17 AM
thanks! and some other not sooo professional (let's say not sooo expensive) ?
04-09-2014 10:45 AM
" (let's say not sooo expensive)"
Unfortunately, as a recommendation from me this is going to be the least expensive choice. There are no others I can give my blessing to. For one thing I generally don't recommend any off-brand lenses and that is where you will have to go.
Only time I will recommend an off-brand lens is if Canon does not make one or the Canon is so ridiculous high priced most folks can't afford it.
You might check out the Canon EF 50mm f/2.5 Compact Macro Standard AutoFocus Lens. I pesonally don't like it.
But it is a reasonable alternative and a little cheaper but remember not even in the same class as the EF 100mm f2.8.
04-09-2014 01:44 PM
@mauriciocayo wrote:thanks! and some other not sooo professional (let's say not sooo expensive) ?
Canon makes two 100mm macro lenses, the L and the “non-L” as recommended above. Just making sure you weren’t looking at the price of the L version ($1000+) vs the non-L (< $600). You could probably get a refurbished L directly from Canon (with warranty) for $450 or so.
I don’t have anything against third party lenses, but I agree with eBiggs on this one; Canon makes some of the best macro lenses out there, and they have a wide assortment of options at different price ranges. Both of the 100mm macros, and the MP-E 65 are some of the best consumer options out there. If it’s not in the budget I’d suggest saving until it is.
04-13-2014 06:23 AM
04-13-2014 11:12 AM
The folks I know that have the EF-S 60mm f/2.8 Macro USM seem to be very happy with it.
Its angle of view is equivalent to a 96mm lens on a FF body.
04-25-2014 11:04 AM
For a macro lens, look at the Tokina AT-X 100mm f/2.8. Does spectacular work as a macro, and doubles as a very good portrait lens also.
04-06-2014 11:19 AM - edited 04-06-2014 11:37 AM
I am not a big fan of any of the lenses you are thinking about. I generally don't like and don't buy EF-S lenses.
So I don't reccommend them to others either.
If I found myself in your shoes I would buy a EF 28-135mm f4-5.6 IS USM and the EF 70-200mm f4L IS. These will work nicely on your 70D and they have the staying power, if and when, you decide to upgrade your camera, too.
