solar eclipse
MichaelLichtman
going to be directly in the path of the total solar eclipse in Aug.  shooting with a 500f4 lens.  will Baader film taped to the hood, be strong enough to shoot partial> full eclipse without harming the lens?
28 REPLIES 28
kvbarkley
VIP
VIP
I don't know what Baader film is, but I had good luck with these:
http://thousandoaksoptical.com/solar.html
If you are lucky, you might not need a filter:
did you tape this on?
The thousand oaks filter comes with a metal ring that I slipped over the lens hood of my 150-600 and secured with tape.
For $3 or $4 bucks you can buy welding glass.  You need to shoot RAW because the welding glass has a green tint which must be corrected in post.  Easy to do.
You will probably need to tract the Sun, too.
If you need to track, you have too much filter. Both my filtered and unfiltered exposures were reasonable. You do need a tripod, though.
My favorite NYC online superstore has a small selection of "solar eclipse" [5.0 ND] filters, including "clear" filters.
And you probably wouldn't want to track. You're not photographing some distant galaxy. Eclipses happen fast, and a tracked image would be blurry and confusing. Maybe OK as a work of art, but not as an accurate record of a once in a lifetime astronomical event.
I hope you'll be luckier than I was. I was literally at the best possible location to view the total solar eclipse of 1964. The American Astronomical Society was there too - invited by my uncle, who was head of the Astronomy Department at the University of Maine. Clouds obliterated the entire event.
Bob
thank you for that great info
Waddizzle
Do a web search for "solar photography filters".  They sell threaded filters that screw on your lenses in many standard sizes.  An 5.0 ND filter is what I have found.
