06-21-2021 11:23 AM
is there an adapter that can run the autofocus on the canon ? Have a fotodiox adapter , but totally manusl .
06-21-2021 11:33 AM
You mean an AF adapter to work a Pentax AF lens on a Canon body for AF? ........No, there isn't and likely never will be.
06-21-2021 12:07 PM
06-22-2021 09:36 AM
It won't work automatically either.
Almost no other camera manufacturer's gear, or off brand accessory, will work correctly with the auto features of a Canon camera. Some third party accessories work fairly well to poorly.
06-24-2021 05:36 PM
Your flashes will work but only in the manual mode with no TTL and HSS (ISO standard center pin connection only), and if they have optical triggers - you can fire them remotely as well. For a studio-type photography that's probably all you need.
For something more like "run-and-gun" when you really need TTL and HSS - 3rd party flashes are pretty cheap these days. You can buy a Yongnuo or Godox in a $100 ballpark that will be 100% compatible with your Canon camera.
06-24-2021 07:11 PM - edited 06-25-2021 06:32 AM
@docusync wrote:Your flashes will work but only in the manual mode with no TTL and HSS (ISO standard center pin connection only), and if they have optical triggers - you can fire them remotely as well. For a studio-type photography that's probably all you need.
I would [not] wish Yongnuo gear on my worst enemy. There are posts all over these forums about Yongnuo gear not being fully compatible with the Canon E-TTL system.
06-25-2021 01:04 AM
Their new flashes like the YN600EX-RT II (the model name looks very similar to Canon's) are fully compatible. It's more like an ethical question if it's ok to use a copy-cat flash. The Godox model (V860 II) would be vastly superior to the Canon 600 EX-RT II, but it's around $200+ (which is still pretty cheap).
This was an offtopic though... Just a recommendation for the OP if they need TTL and HSS "on the cheap", otherwise just stick with what they got, and it'll work just fine.
06-25-2021 11:12 AM
"I would [not] wish Yongnuo gear on my worst enemy. There are posts all over these forums about Yongnuo gear not being fully compatible with the Canon E-TTL system."
Agree, I would never and I don't recommend or advise anyone buying one of these. Just because they look alike doesn't mean a thing about the insides.
06-27-2021 01:55 AM
Never had problems with Yongnuo. While I mostly shoot with strobes these days - I used a bunch of different flashguns including Yongnuo, Profoto, Canon & Godox. The YN600EX-RT II is 99% as good as the "original" Canon, for about 1/4 of the price. If money is not an object - the Profoto A10 would be my choice due to abudance of native modifiers and adapters, fast recycling, iOS compatibility (Profoto Camera), better trigger options and [most important] - I can combine it with large Profoto strobes, and even use the flash as a wireless trigger itself.
06-27-2021 09:12 AM
@docusync wrote:Never had problems with Yongnuo. While I mostly shoot with strobes these days - I used a bunch of different flashguns including Yongnuo, Profoto, Canon & Godox. The YN600EX-RT II is 99% as good as the "original" Canon, for about 1/4 of the price. If money is not an object - the Profoto A10 would be my choice due to abudance of native modifiers and adapters, fast recycling, iOS compatibility (Profoto Camera), better trigger options and [most important] - I can combine it with large Profoto strobes, and even use the flash as a wireless trigger itself.
Your post reminds of the people who claim to have never had any problems using micro-SD memory cards.
