12-02-2020 12:22 AM
I've got a 50mm 0.45/1.5ft f/1.8 lens atm but its not working for me as the focal length which is giving me a hard time shooting everything I want included in a photo.
I'm considering Canon EF 85mm f/1.2L II USM but it is a bit expensive for my taste. Are there any similar lenses for a cheaper price? be it japanese or w/e does not matter to me. I'm looking for the best portrait lens I can get for the cheapest price. Any suggestions?
12-02-2020 12:26 AM
Check out the Canon EF 85mm f:1.8 ... much cheaper and still good quality.
12-02-2020 06:29 AM
@rickharso59 wrote:I've got a 50mm 0.45/1.5ft f/1.8 lens atm but its not working for me as the focal length which is giving me a hard time shooting everything I want included in a photo.
You don't mention which camera you are using, with a full frame camera the 50mm is a normal general purpose lens and may be a bit short for portraits, with a crop camera it acts like like a slightly longer lens and should be more suitable.
You say you can't get everything you want in the photo so that would suggest that you either need to take the shot from a greater distance or get a shorter (more wide angle) lens, an 85mm would be going in the wrong direction.
12-02-2020 08:02 AM
Can you clarify, "not getting everything you want included"? Are you talking about within the frame borders or in terms of keeping what is needed from front to back within critical focus, aka depth of field?
If the problem is keeping everything within the frame and you are in a working environment where you cannot move further back then as Ray noted you will need a shorter focal length instead of longer. If you are going for a highly blurred background but you have to be too close to the model to completely frame the desire content while achieving the desired background blur, then a faster (wider aperture) or longer focal length lens is what you need.
Try a depth of field calculator to look at various combinations of distance, what is in frame, and the depth within critical focus and this will help you decide what focal length and f stop is needed to fit your work parameters. This one is easy to use and includes typical model coverage settings from face to full body as quick presets in the calculation setup:
Don't forget to change the camera/sensor type to APS-C in the calculator if you are using a crop camera.
Rodger
12-02-2020 10:15 AM
Yes, please explain what you mean by "which is giving me a hard time shooting everything I want included in a photo"
Also, please tell us which camera you are using, and what type "models" are you shooting. Do you mean fashion models? Or scale models of plains, trains, automobiles, ships, etc?
12-02-2020 11:33 AM
Easy solution although not a cheap one, a 24-70mm f2.8 or 17-55mm f2.8 zoom.
(FF) (cropper)
