11-15-2016 08:58 PM
Hubby has a Rebel Ti1, 18-55 regular lens and a 55-250 zoom. He wants a wide angle for outdoor, nature photography. Strictly amateur, doen't play around with manual settings much. Any suggestions?
11-15-2016 09:53 PM
The EF-S 10 -18 or the higher quallity EF-S 10-22.
11-16-2016 06:27 AM
@kvbarkley wrote:The EF-S 10 -18 or the higher quallity EF-S 10-22.
The less expensive 10-18 has a smaller max aperture, so would let in less light than the 10-22 but a lot of wide
angle shots are of non-moving scenes, so for that you can just use a tripod and set a longer exposure.
The 10-18 is newer and it is sharper in the corners of the image and 1/2 the price of the 10-22.
I am not familiar with the 3rd party offerings but I know Sigma has a decent 10-20 or so. Not sure if it is a
lot
brighter or cheaper than these other two.
11-16-2016 09:49 AM - edited 11-16-2016 10:23 AM
Both lenses are pretty good. I went for the 10-22 for the wider apeture, wider zoom range, [internal focusing], and the 77mm filter size, which is compatible with most "L" Series lenses. I did not feel I needed Image Stabilization on an ultra-wide angle lens.
