What Canon lenses are best for use on Safari in Kenya?
garymak
Enthusiast
What Canon lenses are best for use on Safari in Kenya?  I am looking for advice based on experience, specifically in Africa, preferably Kenya, on a safari.   ("Experience" means you have first-hand knowledge of the tight spaces and even tighter weight restrictions on in-country flying, which means you have to carefully choose your equipment given these restrictions.)
Body is the R5, and if I can, 5D MKIII as back up.
What would experienced people recommend?
1) Lenses I will bring:
- 16mm pancake (tiny, no weight consideration, and needed for those open plains shots...)
- 24-240mm ƒF4-6.3 IS (not an "L" but good range for travel)
- graduate ND 8 square glass filter for quick holding and eliminating time screwing round filters on and off
- polarizers
2) Lenses I can also bring given the above:
- EF 100-400mmL ƒ/4.5-5.6L IS II USM (+RF adapter)
- RF 600mm ƒ11 IS
- RF 70-200mmL ƒ4 IS
4) For accessories I will bring:
- unfilled bean bag - will scrounge around for beans or something to fill it with since we're dealing with weight restrictions
- Manfrotto PIXI Mini Tripod
- large nylon drawstring bags to put camera in on Land Rover outings.
- WANDRD PRVKE Lite Photography Bag (small, expandable, backside opening, comfortable, waterproof-ish)
5) For accessories what about:
- monopod (I've heard a tripod is impractical and the small Manfrotto works well most of the time and if I need height, I'll find something to put it on)
So, thoughts? I'd appreciate any feedback, suggestions, tips, tricks, considerations, recommendations, and considerations... Thanks!
14 REPLIES 14
@robinh12 wrote:
You are correct. Was being reserved. I had no idea single-use plastic bags had been prohibited since 2017. However, it appears that they still have a plastic problem. I'd be wary of taking a 5D3 on safari, but if this is your backup camera, it'll suffice. It is powered by the same battery as your R5 (good). Taking two bodies is a difficult decision. If something happens to the R5, everything is lost.
Random?  I think maybe you mis-quoted me?  Does this mean we'll get a malicious link in your signature shortly?
@joeySnaps described it perfectly.  The RF 100~400, 600 and 800 non L's don't come with cases, hoods or collars.  They are great lenses, affordable and great for travel.
@garymak, you would probably only need the adapter if you wanted quick on/off.  I don't think you will do a lot of vertical shooting.  Maybe a simple arca plate for it instead.  (like the rest of your gear)
The 24-240 remails a good choice as it might eliminate the need to bring (24-105 and 70-200).  Even at 240 f6.3 you can still get an adequate amount of background blur behind your subject.
Ah! Gotcha!
" I'd be wary of taking a 5D3 on safari" - could you expand on this a little?
ddronron
Thanks so much for your thorough advice.  Given your experience, would the 100-400 mm Canon lens  be the best to take on safari (90% usage )if I don't want to change lenses   I'm thinking my phone can take any shots needed that are close.
