10-26-2013 03:21 PM - edited 10-26-2013 03:52 PM
Hello,
I was wondering if anyone knows whether a Tamron AF28-300mm/3.5-6.3 XR Di lens is compatible with the t5i. According to Tamron's website, it is compatible with the t3i and t4i but does not list the t5i. I was thinking that webpage I referenced may not be up to date. Does anyone know?
Thanks!
Julie ^_^
BTW, the Model number is A061E
10-26-2013 04:32 PM
It will fit & should work as designed but every soo often the odd older lens needs to be re chipped to work properly. If you have the lens already try it out & verify that the AF works properly. There isn't any reason not to install it & take some test shots.
10-26-2013 04:32 PM
10-26-2013 05:47 PM
Ah, I see. I have not purchased the camera yet but I am hoping a reputable camera store will let me try it out. Thanks so much for the information!
Julie
10-26-2013 06:05 PM
I called around and the only place open was a Best Buy by my house. They have one on display and said I could come in and test out my lens. I'll update this after my visit in case anyone else was wondering the same thing. ^_^
10-26-2013 10:03 PM
Okay, I tested it out at Best Buy and it worked great! The AF was working and the test shots of my kiddo looked glorious. Thank you again for your suggestion and help!
10-26-2013 10:06 PM
EXCELLENT
10-07-2016 07:08 PM
I don't know anything about cameras. I have bought a tamron lens for my daughter's birthday but now I wonder whether I've bought the correct one. She has a 750d and I bought a 70-300 tamron lens with 62mm diameter. Will that fit her camera? There ares so many different types and if confused me.
Thanks
10-07-2016 08:09 PM
The 62 mm is to tell you what size (diameter) the threads are on the front of the lens where filters can be mounted. If the box says it fits Canon or lists it as fitting EF or EF-S Canon mounts it will fit. Tamron makes lenses with other styles of mount (for Nikon, Sony etc) so just check the box to verify which brand it will mount to.
