TS-E 17mm and Extender EF 1.4x not working on EOS R
Sojora
Hi everyone. I have a problem trying to used mi Ts-e 17mm lens on a Canon R body (not RP). I been used this lens for a long time on a Canon 6D without any problems but in the Canon R I have the "f00" error message. I already tried the Canon R adaptor with seteable ring, the Canon adaptor without ring and a drop in filter Meike adaptor. In all the cases to verify that it is not a problem with the adapter, I have used other lenses (canon 50mm, 85mm, extender 1.4 and tokina 16-28) and they work well on both cameras but the extender 1.4 or the ts17mm doesn't work. Can anyone help me? Thanks!
29 REPLIES 29
Your TS-E 17mm is not communicating with the [camera], which is why you are seeing “F00” for an aperture value on your cameras.  Your lens is in obvious need of service.
The third party RF-EF mount adapters are known sources of problems, which is probably why Canon forced those products off store shelves.  Owners of the third party products were blaming Canon for their gear not working or being damages.  Your lens may have fallen into the latter category.
ebiggs1
You must not be using a Canon brand tel-con. I don't think they will bolt up to any of Canon's T&S lenses. However,  that is something I have not nor would not ever do. "The third party RF-EF mount adapters are known sources of problems, ...", this is why most of us with decades of experience advise to not use off brand accessories.
Mostly batteries and grips but also true with te-cons.
EOS 1DX and many lenses.
deebatman316
This is straight from the manual. The TS-E 17mm F/4L IS NOT COMPATIBLE with any of Canon's teleconverters. All of their TS-E lenses are INCOMPATIBLE.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
I tried 2 Canon brand mount adapters, one simple, the other with a customizable ring, and one with a Meike brand drop in filter. I don't think that's the problem.
I appreciate your response but I think you are focusing on the extender, and not on the problem itself between the lens and the body R. Regarding the extender 1.4 and the 17mm TS-E lens, I have been using it for 4 years without problems on my Canon 6D.
I tried 2 Canon brand mount adapters, one simple, the other with a customizable ring, and one with a drop in filter Meike brand . I don't think that's the problem. Maybe its a lens issue like you say.
The manual for the lens clearly states that the combination you're trying to use. IS NOT compatible and you should not attempt to use it. Will the lens work without the teleconverter attached. Just with the Canon mount adapter and the TS-E lens.
-Demetrius
Stop using the Meike brand mount adapter.  It is one of those cheap, imported knock-offs that cause error messages and possibly even damage gear.
Like I said, Canon forced that gear off store shelves for good reason.  I suggest that you put it in a drawer somewhere, and then forget where you put it.
Think again.  It’s a problem.  Your damaged lens speaks for itself.  Listen to it.
[EDIT] There have not been any public statements from Canon as for the exact motive for enforcing their copyright.  I can tell you this for certain.  These forums were being flooded with users complaining about their gear not working.
 In many cases, their new camera bodies were being damaged.  I suspect Canon may have found itself in a warranty repair crisis, which is probably something you may not want to talk about in public.
I'm sorry, but you talk as if the problem was all with the Meike mount adapter and it was the third option to test the lens on the Canon EOS R because the other adapters manufactured by Canon do not work. I understand what you are saying, I take the suggestion about the meike brand but I insist that that is not the problem.
