03-16-2024 09:46 AM - last edited on 03-16-2024 09:47 AM by Danny
I am suddenly getting these semi-=opaque double halos around all my shots with my Sigma 1.4 50mm. (These are iPhone screen shots off my LCD.) I've never seen anything like this before. Is there some setting in the camera that is doing this? It does not do it with my 28-15L .
03-16-2024 11:33 AM
A reply I made some time (years) ago to another person seeing the same........
"It apparently happens on only certain Sigma lenses. Perhaps only under certain conditions too. Turn off "lens abberation correction" in the cameras menu, this is designed for Canon lenses and produces ring type patterning when used with some third party lenses."
03-16-2024 11:29 AM
Turn off lens correction.
03-16-2024 11:33 AM
03-16-2024 11:55 AM
As advised above, disable the lens correction setting. Sigma releaed firmware updates for many, if not all, of their lenses that are compatible with the Sigma docking stations.
03-16-2024 05:24 PM
Thanks, all. The firmware USB dock costs $60 so I'll jus live with the lens correction off, since I can correct most anything issues on Lightroom anyway.
03-17-2024 10:18 AM
"Sigma releaed firmware updates for many, ..."
And they used to, don't know if they still do, upgrade FW in their service department. It might be a free service if still under warranty even longer perhaps. Give Sigma a call. They aren't Canon but they used to have an average CS department.
