Repairing 24-70mm 1st version
omerlot
Where do you repair 24-70mm 1st version in LA?
4 REPLIES 4
As in Los Angeles or Louisiana?
If Los Angeles, Steve's Camera Service Center in Culver City seems pretty popular.  I hear even Samy's recommends them.
If Louisiana, then midwestcamera dot com
omerlot
As in Los Angeles 🙂
athanwago
Recently got the dreaded err01 with my 24-70ii. (Tested it on another body and got the error, although less often.) Brought it into a local shop and told them my problem. They said that it's probably the ribbon (flex?) cable inside, which tends to wear overtime when you zoom in and out.
The worker/tech told me that they work on 24-70 lenses nearly everyday and that the problem is very common. Saw in another post here a few days ago saying it's a common problem, too.
ebiggs1
"Where do you repair 24-70mm 1st version in LA?"
I was not aware of any ribbon cable problems with the 1st version of the 24-70mm f2.8L. However, your lens needs to go in for service to ascertain exactly what the problem is. Make sure you get an estimate before hand.
EOS 1DX and many lenses.
