11-11-2025
08:44 PM
10:32 AM
Hello everyone,
I have an r7, and with the rf-s 18-150mm f3.5-6.3 STM, I have been using the af/mf switch on the front of the camera body to switch between focus modes quickly, since the lens has no such switch. Suddenly this switch on the camera body has stopped working. It is still possible to switch between af and mf within the camera menu, and with my other lenses which have an af/mf switch on the lens, the lens switches are all functioning fine when used with the r7.
Can you think of anything i could be missing? Might my camera body need to go to the doctor?
Thanks for any wisdom
11-11-2025 09:29 PM
See if this helps.
When the AF does not operate after switching the focus mode from [MF] to [AF] and when the focus mode is not displayed on the camera’s menu, turn the focus ring in the direction of [Infinity] until the focusing position is within the [AF in-focus range].
• It is not possible to switch the focus mode to [AF] if the focus lens’s focusing position is within the [MF-only range], at which the focus can only be aligned in the MF mode.
• Refer to 3. Taking Closeup Shots in the Manual
Focusing (MF) Mode for further details
See page 7 of the lens manual:
RF-S 18-150 https://share.google/l8oL8cH9on6U4c7gS
~R5 C (1.1.2.1), ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve Studio ~ImageClass MF644Cdw MF656Cdw ~Pixel 10 ~CarePaks Are Worth It
11-12-2025 01:16 AM
Hello!
If the AF/MF switch on your Canon R7 stopped working with the RF-S 18-150mm lens, it’s likely due to a camera setting. This lens lacks a physical focus switch, so the body’s switch only works if enabled in the menu. Check under Menu > AF > Switch (AF/MF) and ensure it’s set to “Enable.” If it’s already enabled and still not working, try updating firmware or resetting custom controls. Otherwise, it may need a service check.
11-12-2025 05:22 AM
For the EOS R7 and EOS R10 the order or priority for the three ways to switch between AF/MF is as follows;
Based on this you must have disabled the AF/MF switch on the camera body for you to be able to select AF/MF in the menu.
11-12-2025 02:42 PM
Thank you! based on your advice I was able to discover that somehow in the wrench menu I had disabled switch af/mf and my camera switch is now working like before
11-12-2025 02:43 PM
Thank you so much for your advice. I had indeed disabled af/ mf switch in wrench menu
11-12-2025 02:44 PM
I did not about this- thank you for taking the time to explain how it works
