07-09-2023 09:44 AM - edited 07-09-2023 09:46 AM
Over the past 2 weeks my RF 24-105 f4 L has begun making an audible squeak from about 50mm on to 105mm. It happens both zooming in and out (though louder when zooming out).
Has anyone else had this happen? I was just in Lebanon for 2 weeks and it’s pretty dusty there, so I’m assuming the dust is causing the squeak.
My lens is out of warranty, and will likely need either repair or maintenance.
Would appreciate any feedback from folks who’ve had this issue, and how they dealt with it.
Thanks for your time.
~K
07-09-2023 12:41 PM - edited 07-09-2023 12:41 PM
You could try zooming all the way in (105mm) an wiping the protruding lens barrel with a slightly damp cloth, then zoom in and out a few times.
07-09-2023 01:13 PM
Tried this before and didn’t have any luck. The squeak sounds like it's coming from the middle of the barrel.
Gets louder the slower you zoom.
07-09-2023 01:26 PM
Try the damp cloth on the zoom ring, especially near the edges of the ring.
07-09-2023 01:33 PM
Just tried this, and still no luck. Also tried cleaning the zoom lock (as this seems like a spot dust might sneak in).
This was a good idea (to clean around the ring) as I am noticing the sound more on the camera side of the zoom ring now as opposed to the lens side (hope this makes sense).
Appreciate the suggestions.
07-10-2023 07:11 PM
You could call 1-800-OK-CANON and talk to the tech people, but they will likely suggest you send it in for service.
07-10-2023 07:30 PM
Called this morning,and ended up sending it in to the Newport News location for repair.
Will report back on my results.
07-10-2023 07:32 PM
Good luck, I hope it doesn't cost too much!
07-14-2023 02:54 PM
Was around $330 with Canon Gold. Lens no longer squeaking.
07-14-2023 03:15 PM
That was a fast turnaround on the repair. Glad to hear that they took care of the squeak.
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
08/18/2023: Canon EOS R5 C training series is released.
