09-01-2024
08:36 AM
09:22 AM
Hello, I have the Canon R5 II, along with the RF 24-105 2.8 and for some reason, I am not able to adjust the aperture in either manual or Aperture Priority mode from the camera. I can change the aperture via the dial on the lens, but not from the camera itself. I don't have any seetings for the control ring or the buttons on the lens (I actually have them off). This only happens with the 24-104 2.8 lens and not any of my other Canon lenses.
Any idea why I can't change the aperture via the camera when this lens is attached? I didn't have this issue with my R5.
09-01-2024 10:14 AM
Make sure aperture ring is set to A on the lens. The aperture ring overrides the setting on the camera.
09-01-2024 10:14 AM
09-01-2024 11:39 AM
Ahh!I didn't realize I had changed that and that was the issue. Thank you very much!!
09-15-2024 03:47 AM
I am experiencing the same problem. How do I set the aperture ring to "A"? I noticed there's an "A" on the lens ring, but I can't find any button to set it. Is there a video or PDF available? It would be great if you could provide some instructions to fix this aperture issue with the R5 Mark II when using the RF 24-105mm f/2.8 lens.
Thank you
09-15-2024 04:43 AM
There is a little lever labeled Iris. Select that and move the Aperture ring to the A position.
