12-02-2025
02:49 PM
02:51 PM
I bought an RF 200-800 lens yesterday to go with my R6 Mark II. After putting the AF/Control/MF switch on Control, I went into the camera and selected "Customize Dials" then selected "Exposure Compensation" for the control ring. While holding the shutter half way down, the control ring does nothing. I have verified that "Exposure Compensation" is set. Does anyone know why the control ring might be non functional?
12-03-2025 01:33 PM
Thank you for the reply. It turns out that the control ring won't work if "Manual" mode is selected. When I select Av or Tv, it works fine.
12-02-2025 04:19 PM
Not home at the moment but will be shortly and I can test with my R5 C / 200-800. By chance to you have BBF enabled? This would remove the ability to program EC to the Control Ring with half press shutter.
12-02-2025 06:08 PM
Is there a button control on the camera body that can also control EC? If so, then the control on the camera will override the lens control ring. The camera will not permit more than one control to able to adjust the same setting.
I have found success by programming the [SET] button for EC. I use multiple camera bodies have found using the [SET] button works on al of them. Hold the button pressed and turn the Main Wheel.
12-03-2025 01:33 PM
07-19-2026 09:28 AM
Just put the switch on the lens to control.
07-20-2026 09:12 AM
I have my EC set to the Quick Control Dial 1 (dial around the set button), it work very well too and I can use my right hand while looking through the viewfinder.
07-20-2026 10:00 AM
This topic is a year and a half old with no activity. The OP indicated that he had set the AF <control> MF switch to control.
