05-13-2024
03:20 PM
09:15 AM
I connected the new RFS 10-18 to my R8 and did not use automatic crop. My R8 has firmware 1.2.0 installed. At the same time, shooting videos and photos is not possible. The display says "manual focus". When the shutter button is pressed, the MF label blinks.
Help me...
05-13-2024 04:13 PM - edited 05-13-2024 04:14 PM
The F00 error indicates the lens and body are not communicating. The fact that you got it connected once without the camera going into crop mode on its own is not correct (again, it signifies a communication failure). FW 1.2.0 added support for the RF-S 10-18 and it should correctly detect and use crop mode if this lens is attached.
I would remove the lens and reset the camera's settings to default both main and custom settings. Then retest. If you continue to experience strange behavior when this lens is attached, I'd contact support.
05-13-2024 03:30 PM
I assume an RF lens works OK?
What do you mean by "did not use automatic crop"? You cannot get a full frame image from an RF-S camera, and I can easily imagine that it would freak out the focus around the area of the frame outside the 1.6X crop.
05-13-2024 03:34 PM
RF lens 15-30 mm works!
Maybe I'm wrong, but I thought that using a RF-S lens on a full-frame camera, I would automatically crop image (1.6x). But this did not happen and the camera cannot record video or photos on the RF-S lens.
05-13-2024 03:39 PM
RF-S 10-18
RF-S 10-18
RF 15-30
05-13-2024 03:40 PM
It does, and if it does not, there is something wrong with the camera or the lens. (look at the second bullet below.)
Does the EXIF data show the correct lens?
05-13-2024 03:41 PM
https://www.youtube.com/shorts/QoBYXZPSTp0
RF-S not work (
05-13-2024 03:47 PM
Movie cropping - on
F00? MF! No rec
Firmware detail
Firmware on camera
05-13-2024 04:25 PM
@shadowsports wrote:Greetings,
Thx
It worked
