10-14-2022 03:48 PM
I recently started surf water photography and I’m looking to upgrade my canon efs 18-55mm lens. I need a lens that is the same/similar size to fit in my water case housing. Thanks for your help!
10-14-2022 03:52 PM
First you need to decide what focal length prime you want and then compare dimensions. That’s something you can do as well as anyone else.
10-14-2022 03:53 PM
Go through your images. (If you have Photos you can create a smart album to do this.) find what focal length you use the most. Then start hunting for a lens at that focal length. Canon has some pancakes that are much smaller!
10-17-2022 11:01 AM
Best "normal" prime for a cropper is one of the 35mm or 28mm lenses. Almost any other is not likely to fit your underwater case.
